WHY! N650DU The fan
  1. WHY! N650DU  The fan, The Batteries: step 1, image 1 of 3 WHY! N650DU  The fan, The Batteries: step 1, image 2 of 3 WHY! N650DU  The fan, The Batteries: step 1, image 3 of 3
    • Unlock the button without spring
    • Slide the battery up while unlocking the button with spring
  2. WHY! N650DU  The fan, Access to major components: step 2, image 1 of 3 WHY! N650DU  The fan, Access to major components: step 2, image 2 of 3 WHY! N650DU  The fan, Access to major components: step 2, image 3 of 3
    • Unscrew the two large screws circled in red
    • Unscrew the two small screws circled in green
    • Slide the plate down and lift the
  3. WHY! N650DU  The fan, The fan: step 3, image 1 of 3 WHY! N650DU  The fan, The fan: step 3, image 2 of 3 WHY! N650DU  The fan, The fan: step 3, image 3 of 3
    • Unscrew the two screws circled in red
    • Disconnect the connector surrounded in green
    • Remove the fan by lifting the blue framed tab
To reassemble your device, Follow these instructions in reverse order.
Special thanks to these translators:
fr en
100%
irlanda is helping us fix the world! Want to contribute?
Start translating ›
Felice Suglia
31,100 Reputation
264 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 2
All Time: 163
