WLAN / Bluetooth Card Replacement
  1. WLAN / Bluetooth Card Replacement, Battery: step 1, image 1 of 3 WLAN / Bluetooth Card Replacement, Battery: step 1, image 2 of 3 WLAN / Bluetooth Card Replacement, Battery: step 1, image 3 of 3
    • Unlock the battery latch on the right.
    • Unlock the battery lock on the left.
    • Remove the battery pack from its slot.
  2. WLAN / Bluetooth Card Replacement, Access to Components 2: step 2, image 1 of 3 WLAN / Bluetooth Card Replacement, Access to Components 2: step 2, image 2 of 3 WLAN / Bluetooth Card Replacement, Access to Components 2: step 2, image 3 of 3
    • Using the Philips # 0 screwdriver, unscrew the 2 screws of the top cover
    • Check the marks indicating the direction in which the cover must be removed.
    • Remove the bottom cover by removing it in the direction of the markers.
  3. WLAN / Bluetooth Card Replacement: step 3, image 1 of 1
    • Then appear the other components of the Laptop.
  4. WLAN / Bluetooth Card Replacement, WLAN / Bluetooth card: step 4, image 1 of 3 WLAN / Bluetooth Card Replacement, WLAN / Bluetooth card: step 4, image 2 of 3 WLAN / Bluetooth Card Replacement, WLAN / Bluetooth card: step 4, image 3 of 3
    • Here is the WLAN Chipset / Bluetooth
    • Gently unplug the MAIN and AUX antennas.
    • Unscrew the fixing screw with Philips # 0 screwdriver.
  5. WLAN / Bluetooth Card Replacement: step 5, image 1 of 2 WLAN / Bluetooth Card Replacement: step 5, image 2 of 2
    • Slightly lift the chipset and remove it from the mSATA connector.
    • Here is the chipset outside of its location.
To reassemble your device follow the following instructions in reverse order
Special thanks to these translators:
fr en
100%
irlanda is helping us fix the world! Want to contribute?
Start translating ›
Felice Suglia
33,538 Reputation
283 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 14
All Time: 573
