WRS315SDHW Control Board Replacement
  1. WRS315SDHW Control Board Replacement, Safety precautions: step 1, image 1 of 1
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. WRS315SDHW Control Board Replacement, Unfasten the dispenser panels: step 2, image 1 of 2 WRS315SDHW Control Board Replacement, Unfasten the dispenser panels: step 2, image 2 of 2
    • The dispenser panel screws are located under the dispenser as if you're looking up into the dispenser tube (where the ice cubes and water come out).
    • Use a 1/4 inch socket wrench to remove the two 15.6 mm-long screws securing the two dispenser panels.
  3. WRS315SDHW Control Board Replacement, Remove the dispenser panels: step 3, image 1 of 3 WRS315SDHW Control Board Replacement, Remove the dispenser panels: step 3, image 2 of 3 WRS315SDHW Control Board Replacement, Remove the dispenser panels: step 3, image 3 of 3
    • Pull the dispenser panels straight down to separate them from the chassis.
    • Remove the dispenser panels.
  4. WRS315SDHW Control Board Replacement, Unfasten the control board: step 4, image 1 of 1
    • Use a 1/4 inch socket wrench to remove the two 15.6 mm-long screws securing the control board.
  5. WRS315SDHW Control Board Replacement: step 5, image 1 of 3 WRS315SDHW Control Board Replacement: step 5, image 2 of 3 WRS315SDHW Control Board Replacement: step 5, image 3 of 3
    • Tilt the bottom of the control board away from the chassis to release its clips.
    • Pull straight down to separate the control board enough to access its connectors.
  6. WRS315SDHW Control Board Replacement, Disconnect the control board: step 6, image 1 of 3 WRS315SDHW Control Board Replacement, Disconnect the control board: step 6, image 2 of 3 WRS315SDHW Control Board Replacement, Disconnect the control board: step 6, image 3 of 3
    • Disconnect the large connector attached to the right edge of the control board.
  7. WRS315SDHW Control Board Replacement: step 7, image 1 of 2 WRS315SDHW Control Board Replacement: step 7, image 2 of 2
    • Disconnect the small connector attached to the left edge of the control board.
  8. WRS315SDHW Control Board Replacement, Remove the control board: step 8, image 1 of 1
    • Remove the control board.
Repair didn’t go as planned? Ask our Answers community for help.
nicO
15,927 Reputation
88 Guides authored
Global Fixers Member of Global Fixers
Community
34 Members
597 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 10
All Time: 183
