WRS315SDHW Dispenser Solenoid Replacement
  1. WRS315SDHW Dispenser Solenoid Replacement, Safety precautions: step 1, image 1 of 1
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. WRS315SDHW Dispenser Solenoid Replacement, Open the doors: step 2, image 1 of 3 WRS315SDHW Dispenser Solenoid Replacement, Open the doors: step 2, image 2 of 3 WRS315SDHW Dispenser Solenoid Replacement, Open the doors: step 2, image 3 of 3
    • Depending on your repair, open one or both doors.
  3. WRS315SDHW Dispenser Solenoid Replacement, Remove the icemaker tray: step 3, image 1 of 2 WRS315SDHW Dispenser Solenoid Replacement, Remove the icemaker tray: step 3, image 2 of 2
    • Pull the icemaker tray completely out of its slot in the chassis.
  4. WRS315SDHW Dispenser Solenoid Replacement, Unfasten the icemaker assembly: step 4, image 1 of 2 WRS315SDHW Dispenser Solenoid Replacement, Unfasten the icemaker assembly: step 4, image 2 of 2
    • Use a 1/4 inch socket wrench to remove the three screws securing the icemaker assembly (shown with the assembly removed):
    • Two 23.9 mm-long screws
    • One 16.7 mm-long screw
  5. WRS315SDHW Dispenser Solenoid Replacement, Reposition the icemaker assembly: step 5, image 1 of 3 WRS315SDHW Dispenser Solenoid Replacement, Reposition the icemaker assembly: step 5, image 2 of 3 WRS315SDHW Dispenser Solenoid Replacement, Reposition the icemaker assembly: step 5, image 3 of 3
    • Pull the icemaker assembly toward the right edge of the refrigerator to release it from its slot in the chassis.
    • Let the icemaker assembly hang to access its connector.
  6. WRS315SDHW Dispenser Solenoid Replacement, Disconnect the icemaker assembly: step 6, image 1 of 3 WRS315SDHW Dispenser Solenoid Replacement, Disconnect the icemaker assembly: step 6, image 2 of 3 WRS315SDHW Dispenser Solenoid Replacement, Disconnect the icemaker assembly: step 6, image 3 of 3
    • Disconnect the spade connector attached to the icemaker assembly.
  7. WRS315SDHW Dispenser Solenoid Replacement, Remove the icemaker assembly: step 7, image 1 of 1
    • Remove the icemaker assembly.
  8. WRS315SDHW Dispenser Solenoid Replacement, Unfasten the icemaker auger assembly: step 8, image 1 of 1
    • Use a 1/4 inch socket wrench to remove the four screws securing the icemaker auger assembly:
    • Two 24.1 mm-long screws
    • Two 16.5 mm-long screws
  9. WRS315SDHW Dispenser Solenoid Replacement, Reposition the icemaker auger assembly: step 9, image 1 of 3 WRS315SDHW Dispenser Solenoid Replacement, Reposition the icemaker auger assembly: step 9, image 2 of 3 WRS315SDHW Dispenser Solenoid Replacement, Reposition the icemaker auger assembly: step 9, image 3 of 3
    • Pull the icemaker auger assembly off of its slot in the chassis.
    • Let the assembly hang to access its connector.
  10. WRS315SDHW Dispenser Solenoid Replacement, Disconnect the icemaker auger assembly: step 10, image 1 of 3 WRS315SDHW Dispenser Solenoid Replacement, Disconnect the icemaker auger assembly: step 10, image 2 of 3 WRS315SDHW Dispenser Solenoid Replacement, Disconnect the icemaker auger assembly: step 10, image 3 of 3
    • Use a flathead screwdriver, or a similar tool, to compress the connector attached to the icemaker auger assembly.
    • Use your hands to disconnect the assembly connector.
  11. WRS315SDHW Dispenser Solenoid Replacement, Remove the icemaker auger assembly: step 11, image 1 of 1
    • Remove the icemaker auger assembly.
  12. WRS315SDHW Dispenser Solenoid Replacement, Remove the dispenser: step 12, image 1 of 3 WRS315SDHW Dispenser Solenoid Replacement, Remove the dispenser: step 12, image 2 of 3 WRS315SDHW Dispenser Solenoid Replacement, Remove the dispenser: step 12, image 3 of 3
    • Slide the dispenser head out of its slot in the icemaker auger assembly.
  13. WRS315SDHW Dispenser Solenoid Replacement: step 13, image 1 of 2 WRS315SDHW Dispenser Solenoid Replacement: step 13, image 2 of 2
    • Remove the dispenser head out of its metal solenoid cube.
  14. WRS315SDHW Dispenser Solenoid Replacement, Remove the tape: step 14, image 1 of 3 WRS315SDHW Dispenser Solenoid Replacement, Remove the tape: step 14, image 2 of 3 WRS315SDHW Dispenser Solenoid Replacement, Remove the tape: step 14, image 3 of 3
    • Peel the tape off the solenoid connector.
    • Set the tape aside. You'll reuse it during reassembly.
  15. WRS315SDHW Dispenser Solenoid Replacement, Disconnect the solenoid: step 15, image 1 of 3 WRS315SDHW Dispenser Solenoid Replacement, Disconnect the solenoid: step 15, image 2 of 3 WRS315SDHW Dispenser Solenoid Replacement, Disconnect the solenoid: step 15, image 3 of 3
    • Pull the solenoid spade connector straight out of the solenoid to disconnect it.
Repair didn’t go as planned? Ask our Answers community for help.
nicO
15,927 Reputation
88 Guides authored
Global Fixers Member of Global Fixers
Community
34 Members
597 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 12
All Time: 81
