WRS315SDHW Evaporator Fan Replacement
  1. WRS315SDHW Evaporator Fan Replacement, Safety precautions: step 1, image 1 of 1
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. WRS315SDHW Evaporator Fan Replacement, Open the doors: step 2, image 1 of 3 WRS315SDHW Evaporator Fan Replacement, Open the doors: step 2, image 2 of 3 WRS315SDHW Evaporator Fan Replacement, Open the doors: step 2, image 3 of 3
    • Depending on your repair, open one or both doors.
  3. WRS315SDHW Evaporator Fan Replacement, Remove the drawers: step 3, image 1 of 2 WRS315SDHW Evaporator Fan Replacement, Remove the drawers: step 3, image 2 of 2
    • Remove the drawers and shelves from the freezer section.
  4. WRS315SDHW Evaporator Fan Replacement: step 4, image 1 of 2 WRS315SDHW Evaporator Fan Replacement: step 4, image 2 of 2
    • Remove the screw(s) securing the evaporator cover.
  5. WRS315SDHW Evaporator Fan Replacement, Unclip the evaporator cover: step 5, image 1 of 3 WRS315SDHW Evaporator Fan Replacement, Unclip the evaporator cover: step 5, image 2 of 3 WRS315SDHW Evaporator Fan Replacement, Unclip the evaporator cover: step 5, image 3 of 3
    • Lift the bottom of the evaporator cover up and over its lip in the chassis.
    • Pull the cover toward yourself to release its top clips.
  6. WRS315SDHW Evaporator Fan Replacement, Remove the evaporator cover: step 6, image 1 of 3 WRS315SDHW Evaporator Fan Replacement, Remove the evaporator cover: step 6, image 2 of 3 WRS315SDHW Evaporator Fan Replacement, Remove the evaporator cover: step 6, image 3 of 3
    • Continue pulling the evaporator cover towards yourself to unclip its metal prongs from the chassis.
    • Remove the evaporator cover.
  7. WRS315SDHW Evaporator Fan Replacement, Disconnect the evaporator fan: step 7, image 1 of 2 WRS315SDHW Evaporator Fan Replacement, Disconnect the evaporator fan: step 7, image 2 of 2
    • Use needle nose pliers, or your fingers, to disconnect the grounding wire attached to the evaporator fan.
  8. WRS315SDHW Evaporator Fan Replacement: step 8, image 1 of 3 WRS315SDHW Evaporator Fan Replacement: step 8, image 2 of 3 WRS315SDHW Evaporator Fan Replacement: step 8, image 3 of 3
    • Disconnect the connector attached to the evaporator fan.
  9. WRS315SDHW Evaporator Fan Replacement, Unfasten the evaporator fan: step 9, image 1 of 1
    • Use a 1/4 inch socket wrench to remove the two 13 mm-long screws securing the evaporator fan.
  10. WRS315SDHW Evaporator Fan Replacement, Remove the foam buffers: step 10, image 1 of 3 WRS315SDHW Evaporator Fan Replacement, Remove the foam buffers: step 10, image 2 of 3 WRS315SDHW Evaporator Fan Replacement, Remove the foam buffers: step 10, image 3 of 3
    • Slide the foam buffer downward to release it from its lip in the chassis.
    • Remove the foam buffer.
    • Repeat this procedure for the second foam buffer.
  11. WRS315SDHW Evaporator Fan Replacement, Remove the evaporator fan housing: step 11, image 1 of 3 WRS315SDHW Evaporator Fan Replacement, Remove the evaporator fan housing: step 11, image 2 of 3 WRS315SDHW Evaporator Fan Replacement, Remove the evaporator fan housing: step 11, image 3 of 3
    • Pull the evaporator fan housing up and outward from the chassis to remove it.
  12. WRS315SDHW Evaporator Fan Replacement, Remove the fan: step 12, image 1 of 2 WRS315SDHW Evaporator Fan Replacement, Remove the fan: step 12, image 2 of 2
    • Pull the evaporator fan straight off its motor to remove it.
    • This may require some significant force.
  13. WRS315SDHW Evaporator Fan Replacement, Remove the motor bracket: step 13, image 1 of 3 WRS315SDHW Evaporator Fan Replacement, Remove the motor bracket: step 13, image 2 of 3 WRS315SDHW Evaporator Fan Replacement, Remove the motor bracket: step 13, image 3 of 3
    • Use your fingers to pry up and release the motor bracket clips from the housing.
  14. WRS315SDHW Evaporator Fan Replacement, Remove the motor bracket: step 14, image 1 of 2 WRS315SDHW Evaporator Fan Replacement, Remove the motor bracket: step 14, image 2 of 2
    • Remove the motor bracket.
  15. WRS315SDHW Evaporator Fan Replacement, Remove the motor: step 15, image 1 of 3 WRS315SDHW Evaporator Fan Replacement, Remove the motor: step 15, image 2 of 3 WRS315SDHW Evaporator Fan Replacement, Remove the motor: step 15, image 3 of 3
    • Pull the motor straight out of its housing to remove it.
Repair didn’t go as planned? Ask our Answers community for help.
nicO
15,927 Reputation
88 Guides authored
Global Fixers Member of Global Fixers
Community
34 Members
597 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 7
All Time: 105
