WRS315SDHW Freezer Door Replacement
  1. WRS315SDHW Freezer Door Replacement, Safety precautions: step 1, image 1 of 1
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. WRS315SDHW Freezer Door Replacement, Open the doors: step 2, image 1 of 3 WRS315SDHW Freezer Door Replacement, Open the doors: step 2, image 2 of 3 WRS315SDHW Freezer Door Replacement, Open the doors: step 2, image 3 of 3
    • Depending on your repair, open one or both doors.
  3. WRS315SDHW Freezer Door Replacement, Unfasten the front panel: step 3, image 1 of 3 WRS315SDHW Freezer Door Replacement, Unfasten the front panel: step 3, image 2 of 3 WRS315SDHW Freezer Door Replacement, Unfasten the front panel: step 3, image 3 of 3
    • Use a Phillips driver to remove the two 15.2 mm-long screws securing the front panel.
  4. WRS315SDHW Freezer Door Replacement, Remove the front panel: step 4, image 1 of 3 WRS315SDHW Freezer Door Replacement, Remove the front panel: step 4, image 2 of 3 WRS315SDHW Freezer Door Replacement, Remove the front panel: step 4, image 3 of 3
    • Pull the front panel straight off the chassis and remove it.
    • You may have to slightly open the water filter door to remove the front panel completely.
  5. WRS315SDHW Freezer Door Replacement, Unfasten the door connections: step 5, image 1 of 2 WRS315SDHW Freezer Door Replacement, Unfasten the door connections: step 5, image 2 of 2
    • Use a 1/4 inch socket wrench to remove the 16.7 mm-long screw securing the freezer door wiring harness.
    • Use a 1/4 inch socket wrench to remove the 16.2 mm-long screw securing the freezer door water hose.
  6. WRS315SDHW Freezer Door Replacement, Reposition the wiring harness: step 6, image 1 of 2 WRS315SDHW Freezer Door Replacement, Reposition the wiring harness: step 6, image 2 of 2
    • Pull the wiring harness out of its slot in the chassis to access its connectors.
  7. WRS315SDHW Freezer Door Replacement, Disconnect the wiring harness: step 7, image 1 of 3 WRS315SDHW Freezer Door Replacement, Disconnect the wiring harness: step 7, image 2 of 3 WRS315SDHW Freezer Door Replacement, Disconnect the wiring harness: step 7, image 3 of 3
    • Disconnect the two connectors attached to the door wiring harness.
  8. WRS315SDHW Freezer Door Replacement: step 8, image 1 of 1
    • Place a clean cloth under the water hose before continuing.
  9. WRS315SDHW Freezer Door Replacement: step 9, image 1 of 2 WRS315SDHW Freezer Door Replacement: step 9, image 2 of 2
    • Pull the plastic clip off the freezer door water hose.
  10. WRS315SDHW Freezer Door Replacement, Disconnect the water hose: step 10, image 1 of 3 WRS315SDHW Freezer Door Replacement, Disconnect the water hose: step 10, image 2 of 3 WRS315SDHW Freezer Door Replacement, Disconnect the water hose: step 10, image 3 of 3
    • Use one hand to compress the blue plastic ring into the green section of the hose.
    • Use the other hand to pull the white water tube out of its slot.
  11. WRS315SDHW Freezer Door Replacement, Unfasten the freezer door: step 11, image 1 of 2 WRS315SDHW Freezer Door Replacement, Unfasten the freezer door: step 11, image 2 of 2
    • Hold the door while performing the next two steps to avoid the door from accidentally falling.
    • Use a 3/16 inch Allen wrench to remove the two 19.3 mm-long screws securing the freezer door.
    • The Torx screws are for alignment and don't need to be removed.
  12. WRS315SDHW Freezer Door Replacement, Remove the door hinge: step 12, image 1 of 3 WRS315SDHW Freezer Door Replacement, Remove the door hinge: step 12, image 2 of 3 WRS315SDHW Freezer Door Replacement, Remove the door hinge: step 12, image 3 of 3
    • Pull the door hinge straight up to separate its alignment pins from the chassis.
    • Remove the door hinge.
  13. WRS315SDHW Freezer Door Replacement, Reposition the cables: step 13, image 1 of 3 WRS315SDHW Freezer Door Replacement, Reposition the cables: step 13, image 2 of 3 WRS315SDHW Freezer Door Replacement, Reposition the cables: step 13, image 3 of 3
    • Pull the freezer door straight up to disconnect it from the chassis.
    • Thread the cables through their slot in the chassis.
    • You may need to thread them individually.
  14. WRS315SDHW Freezer Door Replacement, Remove the door: step 14, image 1 of 2 WRS315SDHW Freezer Door Replacement, Remove the door: step 14, image 2 of 2
    • You're now left with the freezer door.
Repair didn’t go as planned? Ask our Answers community for help.
nicO
15,927 Reputation
88 Guides authored
Global Fixers Member of Global Fixers
Community
34 Members
597 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 85
