WRS315SDHW Icemaker Assembly Replacement
  1. WRS315SDHW Icemaker Assembly Replacement, Safety precautions: step 1, image 1 of 1
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. WRS315SDHW Icemaker Assembly Replacement, Open the doors: step 2, image 1 of 3 WRS315SDHW Icemaker Assembly Replacement, Open the doors: step 2, image 2 of 3 WRS315SDHW Icemaker Assembly Replacement, Open the doors: step 2, image 3 of 3
    • Depending on your repair, open one or both doors.
  3. WRS315SDHW Icemaker Assembly Replacement, Remove the icemaker tray: step 3, image 1 of 2 WRS315SDHW Icemaker Assembly Replacement, Remove the icemaker tray: step 3, image 2 of 2
    • Pull the icemaker tray completely out of its slot in the chassis.
  4. WRS315SDHW Icemaker Assembly Replacement, Unfasten the icemaker assembly: step 4, image 1 of 2 WRS315SDHW Icemaker Assembly Replacement, Unfasten the icemaker assembly: step 4, image 2 of 2
    • Use a 1/4 inch socket wrench to remove the three screws securing the icemaker assembly (shown with the assembly removed):
    • Two 23.9 mm-long screws
    • One 16.7 mm-long screw
  5. WRS315SDHW Icemaker Assembly Replacement, Reposition the icemaker assembly: step 5, image 1 of 3 WRS315SDHW Icemaker Assembly Replacement, Reposition the icemaker assembly: step 5, image 2 of 3 WRS315SDHW Icemaker Assembly Replacement, Reposition the icemaker assembly: step 5, image 3 of 3
    • Pull the icemaker assembly toward the right edge of the refrigerator to release it from its slot in the chassis.
    • Let the icemaker assembly hang to access its connector.
  6. WRS315SDHW Icemaker Assembly Replacement, Disconnect the icemaker assembly: step 6, image 1 of 3 WRS315SDHW Icemaker Assembly Replacement, Disconnect the icemaker assembly: step 6, image 2 of 3 WRS315SDHW Icemaker Assembly Replacement, Disconnect the icemaker assembly: step 6, image 3 of 3
    • Disconnect the spade connector attached to the icemaker assembly.
  7. WRS315SDHW Icemaker Assembly Replacement, Remove the icemaker assembly: step 7, image 1 of 1
    • Remove the icemaker assembly.
Repair didn’t go as planned? Ask our Answers community for help.
nicO
15,927 Reputation
88 Guides authored
Global Fixers Member of Global Fixers
Community
35 Members
603 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 18
All Time: 186
