WRS315SDHW Refrigerator Thermistor Replacement
  1. WRS315SDHW Refrigerator Thermistor Replacement, Safety precautions: step 1, image 1 of 1
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. WRS315SDHW Refrigerator Thermistor Replacement, Open the doors: step 2, image 1 of 3 WRS315SDHW Refrigerator Thermistor Replacement, Open the doors: step 2, image 2 of 3 WRS315SDHW Refrigerator Thermistor Replacement, Open the doors: step 2, image 3 of 3
    • Depending on your repair, open one or both doors.
  3. WRS315SDHW Refrigerator Thermistor Replacement, Unfasten the temperature control board assembly: step 3, image 1 of 2 WRS315SDHW Refrigerator Thermistor Replacement, Unfasten the temperature control board assembly: step 3, image 2 of 2
    • Use a 1/4 inch socket wrench, or a flathead screwdriver, to remove the 22.3 mm-long screw securing the temperature control board assembly (shown with the assembly removed).
  4. WRS315SDHW Refrigerator Thermistor Replacement, Reposition the assembly: step 4, image 1 of 3 WRS315SDHW Refrigerator Thermistor Replacement, Reposition the assembly: step 4, image 2 of 3 WRS315SDHW Refrigerator Thermistor Replacement, Reposition the assembly: step 4, image 3 of 3
    • Pull the temperature control board assembly off its slot in the chassis.
    • Let the assembly hang to access its connectors.
  5. WRS315SDHW Refrigerator Thermistor Replacement, Disconnect the temperature control board: step 5, image 1 of 3 WRS315SDHW Refrigerator Thermistor Replacement, Disconnect the temperature control board: step 5, image 2 of 3 WRS315SDHW Refrigerator Thermistor Replacement, Disconnect the temperature control board: step 5, image 3 of 3
    • Disconnect the two harness connectors attached to the temperature control board assembly.
  6. WRS315SDHW Refrigerator Thermistor Replacement, Remove the assembly: step 6, image 1 of 1
    • Remove the temperature control board assembly.
  7. WRS315SDHW Refrigerator Thermistor Replacement, Disconnect the thermistor: step 7, image 1 of 3 WRS315SDHW Refrigerator Thermistor Replacement, Disconnect the thermistor: step 7, image 2 of 3 WRS315SDHW Refrigerator Thermistor Replacement, Disconnect the thermistor: step 7, image 3 of 3
    • Pinch and pull the connector attached to the thermistor to disconnect it.
  8. WRS315SDHW Refrigerator Thermistor Replacement, Remove the thermistor: step 8, image 1 of 2 WRS315SDHW Refrigerator Thermistor Replacement, Remove the thermistor: step 8, image 2 of 2
    • Use a flathead screwdriver, or a similar tool, to pry up the thermistor from its slot in the chassis.
    • Remove the thermistor.
Repair didn’t go as planned? Ask our Answers community for help.
nicO
15,927 Reputation
88 Guides authored
Global Fixers Member of Global Fixers
Community
34 Members
597 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 21
All Time: 178
