WRS315SDHW Water Filter Housing Replacement
  1. WRS315SDHW Water Filter Housing Replacement, Safety precautions: step 1, image 1 of 1
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. WRS315SDHW Water Filter Housing Replacement, Open the doors: step 2, image 1 of 3 WRS315SDHW Water Filter Housing Replacement, Open the doors: step 2, image 2 of 3 WRS315SDHW Water Filter Housing Replacement, Open the doors: step 2, image 3 of 3
    • Depending on your repair, open one or both doors.
  3. WRS315SDHW Water Filter Housing Replacement, Unfasten the front panel: step 3, image 1 of 3 WRS315SDHW Water Filter Housing Replacement, Unfasten the front panel: step 3, image 2 of 3 WRS315SDHW Water Filter Housing Replacement, Unfasten the front panel: step 3, image 3 of 3
    • Use a Phillips driver to remove the two 15.2 mm-long screws securing the front panel.
  4. WRS315SDHW Water Filter Housing Replacement, Remove the front panel: step 4, image 1 of 3 WRS315SDHW Water Filter Housing Replacement, Remove the front panel: step 4, image 2 of 3 WRS315SDHW Water Filter Housing Replacement, Remove the front panel: step 4, image 3 of 3
    • Pull the front panel straight off the chassis and remove it.
    • You may have to slightly open the water filter door to remove the front panel completely.
  5. WRS315SDHW Water Filter Housing Replacement, Unfasten the water filter housing: step 5, image 1 of 1
    • Use a 1/4 inch socket wrench to remove the two 18.9 mm-long screws securing the water filter housing.
    • Use a 1/4 inch socket wrench, or a flathead screwdriver, to remove the 15.6 mm-long screw securing the wire harness grounding wire.
  6. WRS315SDHW Water Filter Housing Replacement, Reposition the housing: step 6, image 1 of 2 WRS315SDHW Water Filter Housing Replacement, Reposition the housing: step 6, image 2 of 2
    • Pull the housing out of the chassis enough to access its left-hand water connections.
  7. WRS315SDHW Water Filter Housing Replacement, Remove the clips: step 7, image 1 of 3 WRS315SDHW Water Filter Housing Replacement, Remove the clips: step 7, image 2 of 3 WRS315SDHW Water Filter Housing Replacement, Remove the clips: step 7, image 3 of 3
    • Place a clean and dry rag under the water hoses.
    • Use needle nose pliers, or your fingers, to remove the blue clip on the bottom water hose.
    • Repeat for the red clip on the top water hose.
  8. WRS315SDHW Water Filter Housing Replacement, Disconnect the water hoses: step 8, image 1 of 1
    • Compress the plastic ring near the end of the water hose.
    • While compressing the ring, pull the hose away from the ring to disconnect it.
    • Repeat for the other water hose.
  9. WRS315SDHW Water Filter Housing Replacement, Remove the housing: step 9, image 1 of 1
    • Remove the water filter housing.
Repair didn’t go as planned? Ask our Answers community for help.
nicO
15,927 Reputation
88 Guides authored
Global Fixers Member of Global Fixers
Community
35 Members
603 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 8
All Time: 86
