Wacker Plate Compactor VP1430AWAH V-Belt Replacement
  1. Wacker Plate Compactor VP1430AWAH  V-Belt Replacement, Locate the Belt Guard: step 1, image 1 of 1
    • The V-belt is located in a large gray compartment on the left side of the machine
  2. Wacker Plate Compactor VP1430AWAH  V-Belt Replacement, Locate and Loosen the Bolts: step 2, image 1 of 1
    • There are two 1/2 in bolts in the center of the belt guard cover that hold it on. Loosen them using the 1/2 in socket and the 3/8 in drive ratchet, but don't fully remove them
    • Fully removing the bolts will cause a small O-ring to fall loose inside the belt guard
  3. Wacker Plate Compactor VP1430AWAH  V-Belt Replacement, Inspect the Belt: step 3, image 1 of 2 Wacker Plate Compactor VP1430AWAH  V-Belt Replacement, Inspect the Belt: step 3, image 2 of 2
    • Remove the belt guard cover and set it aside
    • Rotate the belt slowly, inspecting for signs of damage such as the crack shown
  4. Wacker Plate Compactor VP1430AWAH  V-Belt Replacement, Remove the Belt: step 4, image 1 of 2 Wacker Plate Compactor VP1430AWAH  V-Belt Replacement, Remove the Belt: step 4, image 2 of 2
    • Pull part of the V-belt up and over the top of the large pulley with one hand
    • Maintain tension on the belt while using your other hand to rotate the pulley clockwise until the belt comes off. This will require a bit of force
    • Remove the belt slowly and be careful not to get your fingers stuck between the belt and pulley
    • Clean any dirt or residue off of the area where the belt rode on the pulleys to ensure the new belt doesn't get any unnecessary wear
  5. Wacker Plate Compactor VP1430AWAH  V-Belt Replacement, Replace the New Belt: step 5, image 1 of 3 Wacker Plate Compactor VP1430AWAH  V-Belt Replacement, Replace the New Belt: step 5, image 2 of 3 Wacker Plate Compactor VP1430AWAH  V-Belt Replacement, Replace the New Belt: step 5, image 3 of 3
    • Loop the bottom of the belt around the small pulley
    • Pull the top of the belt around the bottom of the large pulley
    • Slowly twist the top pulley counter-clockwise while maintaining tension on the belt until the belt is completely on. This will require a bit of force
    • Be careful not to get your fingers caught between the belt and pulley as you rotate the new belt on
  6. Wacker Plate Compactor VP1430AWAH  V-Belt Replacement, Clean the Belt Guard: step 6, image 1 of 1
    • Lightly pressure wash or otherwise clean the inside of the belt guard and belt guard cover. This will reduce wear and damage on the new belt
  7. Wacker Plate Compactor VP1430AWAH  V-Belt Replacement, Replace the Belt Guard: step 7, image 1 of 2 Wacker Plate Compactor VP1430AWAH  V-Belt Replacement, Replace the Belt Guard: step 7, image 2 of 2
    • Line up the cover of the belt guard and place each bolt in its respective hole
    • Firmly press the belt guard cover into the rubber molding of the belt guard case to ensure proper sealing
    • Tighten the bolts firmly with a 1/2 in socket and a 3/8 in drive ratchet
Congrats! Your belt is now replaced.
Please give this guide a favorite and like if you found it helpful and please leave your feedback in the comments below. Thank you and have a great rest of your day.
3 other people completed this guide.
ZACHARY
421 Reputation
2 Guides authored
The Home Depot Member of The Home Depot
Community
21,844 Members
58 Guides authored
2 Guide Comments
In step #2 they are NOT 1/2in bolts, they are 5/16in bolts , please learn how bolts are measured before posting false information
JAMES - Reply
To be fair, mine were all 1/2 inch, sounds like yours were replaced with a different size. Maybe fact check before you accuse people of posting false info
GREGORY - Reply
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 56
All Time: 3,968
