Wacom Cintiq 24HD Power Supply Replacement
  1. Wacom Cintiq 24HD Power Supply Replacement, Power Supply: step 1, image 1 of 1
    • Procurement of a suitable commercially available power pack.
    • Type GST120A24R7B
    • R7B is important as this is the only connector that fits the Wacom tablet. (Connector type KYCON KPPX-4).
    • Performance data 120W, 24 volts
    • The power pack opens. To do this, the four rubber plugs are removed and the four screws are removed with a Phillips screwdriver. The housing can then be easily removed.
    • The 24V side has four wires: black, blue, red and white. These are soldered and can be removed.
    • The black and blue wire is soldered to the minus output (V-). The red and white wire is soldered to the 24V (V+) output. Note: The black wire is connected to the metal body of the plug.
    • The power supply will reassemble and can now be connected to the Wacom Tablet.
    • Test: According to the assignment in the picture, after resoldering the lines, the ground line must be on the upper 2 pins and the +24V voltage on the lower 2 pins
Work the steps in reverse order to reassemble your device.
Special thanks to these translators:
de en
100%
HelloMacOS is helping us fix the world! Want to contribute?
Start translating ›
Wilfried Weigelt
85 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 28
All Time: 1,078
