Wacom Intuos CTL4100 Battery Replacement
  1. Wacom Intuos CTL4100 Battery Replacement, Battery: step 1, image 1 of 3 Wacom Intuos CTL4100 Battery Replacement, Battery: step 1, image 2 of 3 Wacom Intuos CTL4100 Battery Replacement, Battery: step 1, image 3 of 3
    • Flip the tablet over so the bottom case faces upwards.
    • Remove the rubber pads on the corners by pulling them up with your fingers.
  2. Wacom Intuos CTL4100 Battery Replacement: step 2, image 1 of 3 Wacom Intuos CTL4100 Battery Replacement: step 2, image 2 of 3 Wacom Intuos CTL4100 Battery Replacement: step 2, image 3 of 3
  3. Wacom Intuos CTL4100 Battery Replacement: step 3, image 1 of 3 Wacom Intuos CTL4100 Battery Replacement: step 3, image 2 of 3 Wacom Intuos CTL4100 Battery Replacement: step 3, image 3 of 3
    • Insert a plastic opening pick between the front and back case to unclip the clips that hold the cases together.
    • Slide your plastic opening pick around the sides until all clips are unclipped.
  4. Wacom Intuos CTL4100 Battery Replacement: step 4, image 1 of 2 Wacom Intuos CTL4100 Battery Replacement: step 4, image 2 of 2
    • Lift the bottom case to separate the top and bottom case
    • When you see the internal components, set aside the bottom case.
  5. Wacom Intuos CTL4100 Battery Replacement: step 5, image 1 of 2 Wacom Intuos CTL4100 Battery Replacement: step 5, image 2 of 2
    • Remove the yellow tape that is on top of the battery wires.
    • When the battery wires under the tape are exposed, stick the yellow tape just above the battery wires.
  6. Wacom Intuos CTL4100 Battery Replacement: step 6, image 1 of 2 Wacom Intuos CTL4100 Battery Replacement: step 6, image 2 of 2
    • Gently pull up the battery wire pin with your fingers to disconnect the pin from the motherboard.
  7. Wacom Intuos CTL4100 Battery Replacement: step 7, image 1 of 2 Wacom Intuos CTL4100 Battery Replacement: step 7, image 2 of 2
    • Remove the battery by lifting the battery up with your fingers.
  8. Wacom Intuos CTL4100 Battery Replacement: step 8, image 1 of 1
    • Place the new battery on the area you removed the battery.
  9. Wacom Intuos CTL4100 Battery Replacement: step 9, image 1 of 2 Wacom Intuos CTL4100 Battery Replacement: step 9, image 2 of 2
    • Gently connect the battery wire pin to the motherboard.
  10. Wacom Intuos CTL4100 Battery Replacement: step 10, image 1 of 2 Wacom Intuos CTL4100 Battery Replacement: step 10, image 2 of 2
    • Reapply the tape you put above the battery wires.
To reassemble your device, follow step 4 in reverse order.
3 other people completed this guide.
Marcus Sisouphanh
262 Reputation
1 Guide authored
3 Comments
Where did you get the replacement battery?
David VeLar - Reply
Will it work without a battery?
Jordi Prats - Reply
Answering my own question, yes, it works without a battery. It will popup a notification of low battery sometimes, and obviously it won't work wirelessly.
Ah, and I tried this with a CTL6100 tablet, so this guide is valid for this model as well (a bit larger but mostly identical inside).
Jordi Prats -
Past 24 Hours: 2
Past 7 Days: 20
Past 30 Days: 102
All Time: 3,702
