Wacom Intuos Pro Battery Replacement
  1. Wacom Intuos Pro Battery Replacement, Battery: step 1, image 1 of 3 Wacom Intuos Pro Battery Replacement, Battery: step 1, image 2 of 3 Wacom Intuos Pro Battery Replacement, Battery: step 1, image 3 of 3
    • Orient the device so the bottom casing is facing upwards.
    • Use your fingers to gently pull on the rubber covers on the bottom of the device to remove them.
  2. Wacom Intuos Pro Battery Replacement: step 2, image 1 of 3 Wacom Intuos Pro Battery Replacement: step 2, image 2 of 3 Wacom Intuos Pro Battery Replacement: step 2, image 3 of 3
    • Remove the four 4mm screws from underneath the rubber feet using a Phillips #00 screwdriver.
    • The screws are located 40mm in from the edge, so it not necessary to completely remove the rubber if you prefer not to.
  3. Wacom Intuos Pro Battery Replacement: step 3, image 1 of 2 Wacom Intuos Pro Battery Replacement: step 3, image 2 of 2
    • Insert the iFixit Opening Tool between the front and back cover of the device in order to snap and separate the type locks from around the edges.
    • Use the iFixit Opening Tool all the way around the edges until all the snaps have been released.
    • While going around the edges, make sure you have a tight grip to keep the device from sliding.
  4. Wacom Intuos Pro Battery Replacement: step 4, image 1 of 2 Wacom Intuos Pro Battery Replacement: step 4, image 2 of 2
    • Remove the case backing from the rear of the device with your hands so the internal components are exposed.
  5. Wacom Intuos Pro Battery Replacement: step 5, image 1 of 2 Wacom Intuos Pro Battery Replacement: step 5, image 2 of 2
    • If not already done, desolder the three colored cables that connect the battery to the motherboard.
    • After desoldering the battery, carefully remove it.
    • Be careful when handling the soldering iron given it's high operating temperature and the possibility for it to damage other components.
    • For help soldering, check out our How to Solder and Desolder Connections guide.
3 other people completed this guide.
6 Guide Comments
thank you so much. I plan to buy this wacom, however I had the doubt if better the old version that has extractable battery, but with this post, I can go for the new one
Sebastian Ramirez - Reply
Do you know where can I find the battery replacement?
Valerio _ - Reply
Has anyone got a lint to the replacement battery?
Luca Di Meo - Reply
PTH-660 works fine without the battery, just remove it and use it with USB cable
Luca Di Meo - Reply
Where can I find a replacement battery for this model?
Denise Hanly - Reply
Past 24 Hours: 6
Past 7 Days: 41
Past 30 Days: 177
All Time: 10,331
