Wacom Intuos4 Motherboard Replacement
  1. Wacom Intuos4 Motherboard Replacement, Casing: step 1, image 1 of 3 Wacom Intuos4 Motherboard Replacement, Casing: step 1, image 2 of 3 Wacom Intuos4 Motherboard Replacement, Casing: step 1, image 3 of 3
    • Flip device on its back and remove all fourteen 7.1 mm screws using a Phillips #1 screwdriver.
    • There is a single screw located under each of the rubber leg pieces. Use a shimmy tool to remove these pieces to access the screws.
  2. Wacom Intuos4 Motherboard Replacement: step 2, image 1 of 2 Wacom Intuos4 Motherboard Replacement: step 2, image 2 of 2
    • Lift the screen's foam backing connecting the motherboard/drawing board to the two smaller express-key boards, placing it onto the motherboard.
    • Separate the outer casing from the rest of the tablet.
  3. Wacom Intuos4 Motherboard Replacement, Motherboard: step 3, image 1 of 2 Wacom Intuos4 Motherboard Replacement, Motherboard: step 3, image 2 of 2
    Tool used on this step:
    Buy
    • Using tweezers, remove the yellow tape covering the three cable connectors.
  4. Wacom Intuos4 Motherboard Replacement: step 4, image 1 of 2 Wacom Intuos4 Motherboard Replacement: step 4, image 2 of 2
    • Lift the black plastic clip holding the flat wire to the connector with either tweezers or an iFixit opening tool.
    • Pull on the white plastic tab to disconnect the flat wire.
  5. Wacom Intuos4 Motherboard Replacement: step 5, image 1 of 2 Wacom Intuos4 Motherboard Replacement: step 5, image 2 of 2
    • Carefully remove the motherboard from the casing.
    • If you're having trouble, don't force it. Make sure all cables are disconnected and all screws are removed.
Jack Palmgren
234 Reputation
2 Guides authored
UMass Dartmouth, Team 3-6, Botvin Fall 2022 Member of UMass Dartmouth, Team 3-6, Botvin Fall 2022
UMASSD-BOTVIN-F22S3G6
4 Members
10 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 19
All Time: 279
