Introduction
The Wacom Intuos4s touch ring is useful for navigating your computer quickly. If the keys become loose, damaged or otherwise work improperly this guide will help you fix them.
This guide was created with a model PTK-640 Wacom Intuos4. Different models may vary in design.
Flip device on its back and remove all fourteen 7.1 mm screws using a Phillips #1 screwdriver.
There is a single screw located under each of the rubber leg pieces. Use a shimmy tool to remove these pieces to access the screws.
Using tweezers, remove the yellow tape covering the three cable connectors.
