Wahl Chrome Pro Motor Replacement
  1. Wahl Chrome Pro Motor Replacement, Case: step 1, image 1 of 1
    • Remove the two 5.0 mm JIS #1 screws to loosen the cutting blades.
    • Make sure your device is not connected to power before you begin.
  2. Wahl Chrome Pro Motor Replacement: step 2, image 1 of 1
    • Lift the bottom blade straight up from the device body to remove it.
  3. Wahl Chrome Pro Motor Replacement: step 3, image 1 of 1
    • Remove the three 9.0 mm JIS #1 screws attaching the base of the blade assembly to the body.
  4. Wahl Chrome Pro Motor Replacement: step 4, image 1 of 1
    • Lift the base of blade assembly straight up off of the body.
  5. Wahl Chrome Pro Motor Replacement: step 5, image 1 of 1
    • Remove the two 12.0 mm JIS #1 screws on the back of the device body.
  6. Wahl Chrome Pro Motor Replacement: step 6, image 1 of 1
    • Remove the 13.0 mm Phillips #2 screw on the side of the device body.
    • This screw is located on the opposite side of the body from the switch.
  7. Wahl Chrome Pro Motor Replacement: step 7, image 1 of 1
    Tool used on this step:
    Buy
    • Remove the spring on the side of the body using tweezers.
  8. Wahl Chrome Pro Motor Replacement: step 8, image 1 of 1
    • Pry the body case off of the device using a spudger.
  9. Wahl Chrome Pro Motor Replacement, Motor: step 9, image 1 of 1
    • Lift power cord tab (black wire) from slot on motor base.
  10. Wahl Chrome Pro Motor Replacement: step 10, image 1 of 1
    • Lift switch tab (teal wire) from slot on motor base.
  11. Wahl Chrome Pro Motor Replacement: step 11, image 1 of 1
    • Remove two 23.0 mm JIS #1 screws attaching motor base to device body.
  12. Wahl Chrome Pro Motor Replacement: step 12, image 1 of 1
    • Lift motor base straight up from device body to remove.
2 other people completed this guide.
Ashley Dale
285 Reputation
2 Guides authored
IUPUI, Team S7-G3, Baechle Fall 2017 Member of IUPUI, Team S7-G3, Baechle Fall 2017
IUPUI-BAECHLE-F17S7G3
3 Members
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 13
All Time: 1,269
