Wahl Hair Clippers Model ST115VAC Power Cord Replacement
  1. Wahl Hair Clippers  Model ST115VAC Power Cord  Replacement, Power Cord: step 1, image 1 of 1
    • Unscrew the three 12mm black JIS screw found on the red side of the the device with a JIS #1 driver.
  2. Wahl Hair Clippers  Model ST115VAC Power Cord  Replacement: step 2, image 1 of 1
    • Grab the red cover by the side and lift off the top piece.
  3. Wahl Hair Clippers  Model ST115VAC Power Cord  Replacement: step 3, image 1 of 1
    • Unscrew the 5.556mm screw with a JIS #0 screwdriver. (Black Screw located at power switch)
  4. Wahl Hair Clippers  Model ST115VAC Power Cord  Replacement: step 4, image 1 of 1
    Tool used on this step:
    Spudger
    $2.99
    Buy
    • Insert the metal spudger between the wire connector and the device connector. The spudger should disengage a tension-like lock between both connectors, and once disengaged gently pry out the cord connection.
    • (Note-dependent on varying user conditions, the connection may be harder to remove and may involve more force or a gentle rocking to separate connection.)
    • When working with electronics, make to use an ESD safe tool, to avoid shock. Try using the black nylon spudger instead.
  5. Wahl Hair Clippers  Model ST115VAC Power Cord  Replacement: step 5, image 1 of 1
    • Remove the cord from the fixed position.
To reassemble your device, follow these instructions in reverse order. When installing new cord, make sure black wire is underneath the white wire.
3 other people completed this guide.
Julio Alvarado
131 Reputation
1 Guide authored
USF Tampa, Team 10-4, Remmell Spring 2017 Member of USF Tampa, Team 10-4, Remmell Spring 2017
USFT-REMMELL-S17S10G4
4 Members
1 Guide authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 26
All Time: 2,993
