Wahl Lithium Ion Trimmer Metal Razor Arms Replacement
nathan
nathan and 8 other contributors
Last updated on January 9, 2025
10 - 15 minutes
Easy
Action Shots
Needs Better Images
Introduction
Go to step 1
If the blades to your Wahl Lithium Ion Trimmer are damaged or worn, this guide will show you how to replace them with functioning blades.
Blades can be damaged by being dropped, misused, or not being properly taken care of. In any of these circumstances, a replacement is typically required.
Because the blades are sharp, make sure to wear gloves or some sort of hand protection while handling the blades in order to avoid any sort of injury.
Before beginning this guide, make sure that the Wahl Lithium Ion Trimmer is powered off and disconnected from any source of electricity.
Tools
iFixit earns commission when you buy through these links.
  1. Wahl Lithium Ion Trimmer Metal Razor Arms Replacement, Metal Razor Arms: step 1, image 1 of 1
    • Examine the razor to identify any broken or jammed blades, if any the whole set must be changed.
  2. Wahl Lithium Ion Trimmer Metal Razor Arms Replacement: step 2, image 1 of 1
    • Unscrew the two Phillips screws with a Phillips #0 screwdriver.
    • Set those two screws aside for reassembly.
  3. Wahl Lithium Ion Trimmer Metal Razor Arms Replacement: step 3, image 1 of 1
    • Apply pressure to the back side of the blades while pushing outward to completely remove the blade head.
  4. Wahl Lithium Ion Trimmer Metal Razor Arms Replacement: step 4, image 1 of 3 Wahl Lithium Ion Trimmer Metal Razor Arms Replacement: step 4, image 2 of 3 Wahl Lithium Ion Trimmer Metal Razor Arms Replacement: step 4, image 3 of 3
    • Put the Phillips #0 screwdriver in the opening and pry out the metal clip.
    • Set aside the metal clip for reassembly
  5. Wahl Lithium Ion Trimmer Metal Razor Arms Replacement: step 5, image 1 of 1
    • Separate the Wahl Lithium Ion Trimmer head into its four components.
    • Remove the damaged blade and replace it with a new one.
4 other people completed this guide.
nathan
1,422 Reputation
6 Guides authored
3 Comments
Where can I get replacement arms?
Sam - Reply
Where can one obtain a new spring???
tinkrmann - Reply
The spring popped out of the head, but your pictures are too blurry to see how it goes back together.
Mark Wilson - Reply
Past 24 Hours: 4
Past 7 Days: 14
Past 30 Days: 46
All Time: 19,615
