Wahl Lithium Ion Trimmer Metal Razor Arms Replacement
  1. Wahl Lithium Ion Trimmer Metal Razor Arms Replacement, Metal Razor Arms: step 1, image 1 of 1
    • Examine the razor to identify any broken or jammed blades, if any the whole set must be changed.
  2. Wahl Lithium Ion Trimmer Metal Razor Arms Replacement: step 2, image 1 of 1
    • Unscrew the two Phillips screws with a Phillips #0 screwdriver.
    • Set those two screws aside for reassembly.
  3. Wahl Lithium Ion Trimmer Metal Razor Arms Replacement: step 3, image 1 of 1
    • Apply pressure to the back side of the blades while pushing outward to completely remove the blade head.
  4. Wahl Lithium Ion Trimmer Metal Razor Arms Replacement: step 4, image 1 of 3 Wahl Lithium Ion Trimmer Metal Razor Arms Replacement: step 4, image 2 of 3 Wahl Lithium Ion Trimmer Metal Razor Arms Replacement: step 4, image 3 of 3
    • Put the Phillips #0 screwdriver in the opening and pry out the metal clip.
    • Set aside the metal clip for reassembly
    Any chance of getting a clearer, closer, better lit shot of the assembled head? Mine has fallen apart, and this is the closest I have found to a picture of what it should look like. If only it were clearer...
    Nicholas Sterling - Reply
  5. Wahl Lithium Ion Trimmer Metal Razor Arms Replacement: step 5, image 1 of 1
    • Separate the Wahl Lithium Ion Trimmer head into its four components.
    • Remove the damaged blade and replace it with a new one.
    how to put back spring?
    Thokozani Xhakaza - Reply
    Ok I am at that point how do I put it back together
    alberthughes961 - Reply
4 other people completed this guide.
nathan
1,422 Reputation
6 Guides authored
3 Comments
Where can I get replacement arms?
Sam - Reply
Where can one obtain a new spring???
tinkrmann - Reply
The spring popped out of the head, but your pictures are too blurry to see how it goes back together.
Mark Wilson - Reply
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 54
All Time: 19,623
