Wahl Professional Designer Motor Replacement
  1. Wahl Professional Designer Motor Replacement, Motor: step 1, image 1 of 2 Wahl Professional Designer Motor Replacement, Motor: step 1, image 2 of 2
    • Unscrew the 12 mm Phillips head screws located at the top of the cover and at the bottom two corners, using a Phillips #1 Screwdriver.
  2. Wahl Professional Designer Motor Replacement: step 2, image 1 of 3 Wahl Professional Designer Motor Replacement: step 2, image 2 of 3 Wahl Professional Designer Motor Replacement: step 2, image 3 of 3
    • Remove the wires connected to the motor by firmly grasping both sides of a wire and wiggling until it is released.
  3. Wahl Professional Designer Motor Replacement: step 3, image 1 of 3 Wahl Professional Designer Motor Replacement: step 3, image 2 of 3 Wahl Professional Designer Motor Replacement: step 3, image 3 of 3
    • Unscrew the two 20.5 mm Phillip head screw located on the motor using a Phillip's #1 screwdriver.
  4. Wahl Professional Designer Motor Replacement: step 4, image 1 of 2 Wahl Professional Designer Motor Replacement: step 4, image 2 of 2
    • Gently remove the motor from the device.
Sophia Swearengin
718 Reputation
5 Guides authored
USF Tampa, Team S14-G5, Boczar Fall 2017 Member of USF Tampa, Team S14-G5, Boczar Fall 2017
USFT-BOCZAR-F17S14G5
2 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 11
All Time: 1,214
