Introduction
If your device is not working due to a problem with your power cord this guide will allow you to replace it to fix your problem.
Unscrew the 12 mm Phillips head screws located at the top of the cover and at the bottom two corners, using a Phillips #1 Screwdriver.
Almost done!
