Wahl Professional Designer Power Switch Replacement
  1. Wahl Professional Designer Power Switch Replacement, Power Switch: step 1, image 1 of 2 Wahl Professional Designer Power Switch Replacement, Power Switch: step 1, image 2 of 2
    • Unscrew the 12 mm Phillips head screws located at the top of the cover and at the bottom two corners, using a Phillips #1 Screwdriver.
  2. Wahl Professional Designer Power Switch Replacement: step 2, image 1 of 2 Wahl Professional Designer Power Switch Replacement: step 2, image 2 of 2
    • Unscrew the two black 5.556 mm Phillip head screw on the power switch with a Phillips #0 Screwdriver.
  3. Wahl Professional Designer Power Switch Replacement: step 3, image 1 of 3 Wahl Professional Designer Power Switch Replacement: step 3, image 2 of 3 Wahl Professional Designer Power Switch Replacement: step 3, image 3 of 3
    • Shimmy the power switch off the mount until it is completely removed.
Sophia Swearengin
718 Reputation
5 Guides authored
USF Tampa, Team S14-G5, Boczar Fall 2017 Member of USF Tampa, Team S14-G5, Boczar Fall 2017
USFT-BOCZAR-F17S14G5
2 Members
5 Guides authored
One Comment
Hello Mrs/ms Swearengin, I’m disassembled my Wahl desingner I’m unable to make the power switch stiff . It’s very loose I can’t recall which screw goes in between two black 5.556 mm Phillip head screw or if it needs a screw at all
Carlos Olvera - Reply
Past 24 Hours: 3
Past 7 Days: 4
Past 30 Days: 13
All Time: 583
