Waring 51BL29 Drive Coupling Replacement
  1. Waring 51BL29 Drive Coupling Replacement, Bottom Panel: step 1, image 1 of 2 Waring 51BL29 Drive Coupling Replacement, Bottom Panel: step 1, image 2 of 2
    • Turn the blender on its side so the bottom panel is facing you.
    • Unscrew the 22mm Phillips #1 screw on the indent of the panel.
    • Unscrew the 3 screws in the rubber holes.
  2. Waring 51BL29 Drive Coupling Replacement: step 2, image 1 of 1
    • Remove the bottom panel.
  3. Waring 51BL29 Drive Coupling Replacement, Drive Coupling: step 3, image 1 of 1
    • Place the screwdriver in the head of the middle flat-head screw.
  4. Waring 51BL29 Drive Coupling Replacement: step 4, image 1 of 1
    • Unscrew this screw while holding the coupling with your other hand and not allowing it to rotate.
    • This screw may be reverse-threaded.
  5. Waring 51BL29 Drive Coupling Replacement: step 5, image 1 of 1
    • Once the coupling mechanism has been loosened all the way, gently pull it off the top of the blender.
4 other people completed this guide.
Dean Becker
470 Reputation
4 Guides authored
Cal Poly, Team S15-G4, Banghart Spring 2017 Member of Cal Poly, Team S15-G4, Banghart Spring 2017
CPSU-BANGHART-S17S15G4
4 Members
5 Guides authored
1 Guide Comment
Do you happen to know where I can purchase this replacement part?
Jessica Dye - Reply
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 32
All Time: 8,485
