Water Damage on main board of Nokia 206 RM873
  1. Water Damage on main board of Nokia 206 RM873, Water Damage on main board of Nokia 206 RM873: step 1, image 1 of 3 Water Damage on main board of Nokia 206 RM873, Water Damage on main board of Nokia 206 RM873: step 1, image 2 of 3 Water Damage on main board of Nokia 206 RM873, Water Damage on main board of Nokia 206 RM873: step 1, image 3 of 3
    • Remove back cover & battery.
  2. Water Damage on main board of Nokia 206 RM873: step 2, image 1 of 2 Water Damage on main board of Nokia 206 RM873: step 2, image 2 of 2
    • Remove the front case by prying it open. You will hear clicks.
    • Be careful with taking off screen if you use a spudger.
  3. Water Damage on main board of Nokia 206 RM873: step 3, image 1 of 2 Water Damage on main board of Nokia 206 RM873: step 3, image 2 of 2
    Tool used on this step:
    Buy
    • Use a Torx screwdriver to remove the screen screws.
    • Use a spudger or tweezers to remove the connector of the LCD screen.
  4. Water Damage on main board of Nokia 206 RM873: step 4, image 1 of 3 Water Damage on main board of Nokia 206 RM873: step 4, image 2 of 3 Water Damage on main board of Nokia 206 RM873: step 4, image 3 of 3
    • The PCB board had water damage, see this in picture 3.
    • To remove the corrosion, dab a cotton swab with a little distilled water on the corroded area, the corrosion will disappear.
  5. Water Damage on main board of Nokia 206 RM873: step 5, image 1 of 2 Water Damage on main board of Nokia 206 RM873: step 5, image 2 of 2
    • How and where to use the cotton swabs.
17 other people completed this guide.
Kevin D
7,316 Reputation
21 Guides authored
4 Comments
no use .it is not switching on . replaced with good batter also. no on
nabhan75 - Reply
try to clean with an ultrasonic bath.
measure out powerrail.
measure out the voltage coming in on board. try to see if you have short.
Kevin D - Reply
Nokia 206 display and charger pin
Mithilesh Yadav - Reply
Not working kiy 1.2.3 and colling ricev kiy not working
K .M Jugesh - Reply
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 25
All Time: 10,852
