Water Tank Sealing Replacement
  1. Water Tank Sealing Replacement, Jura Impressa Type C E F opening procedure: step 1, image 1 of 1
    • The instructions are suitable for nearly every model of Jura and similar ones e.g. AEG and Krups.
    • Unplug!
    • Remove the water reservoir.
  2. Water Tank Sealing Replacement: step 2, image 1 of 3 Water Tank Sealing Replacement: step 2, image 2 of 3 Water Tank Sealing Replacement: step 2, image 3 of 3
    Tool used on this step:
    iFixit Precision 4 mm Screwdriver Bit
    $2.99
    Buy
    • On the rear side is an obstacle: four "oval head screws" looking like rivets. You can remove them using a special oval drive bit. They are sold at iFixit with the tool kits as well as some Jura suppliers or somewhere in the internet. Jura wants to keep us out of our own machines!
    • Using an oval head bit you can screw them out. If you haven´t got one you can carefully use pliers. It is a good idea to later change the screws for normal ones.
    • You can even create your own specialty tool
    • Beneath both top side covers are two Torx T15 screws. Remove those. Now lift off the whole top cover. Sometimes it jams and you have to use a bit of force.
    • The side covers must be pushed backwards by about 1 cm. Sometimes this is a little bit difficult to move. If necessary, wedge a plastic opening tool into the gap between the side covers and the front panel. The rear cover can be easily removed.
  3. Water Tank Sealing Replacement, Lift support: step 3, image 1 of 2 Water Tank Sealing Replacement, Lift support: step 3, image 2 of 2
    • The support of the sealing is secured by a screw, mostly Tx 15.
    • On the left and right side are notches, open them and raise the support.
    • Turn it upside down.
  4. Water Tank Sealing Replacement, Replace sealing: step 4, image 1 of 3 Water Tank Sealing Replacement, Replace sealing: step 4, image 2 of 3 Water Tank Sealing Replacement, Replace sealing: step 4, image 3 of 3
    • Press both plastic rivets with tiers, then push them out. The cover of the sealing is free.
    • Change sealings. The old one was black, the new one red.
    • Attach cover
Now follow the steps in reverse direction.
4 other people completed this guide.
Special thanks to these translators:
de en
100%
VauWeh is helping us fix the world! Want to contribute?
Start translating ›
VauWeh
212,891 Reputation
265 Guides authored
Repair is War on Entropy Member of Repair is War on Entropy
Community
27 Members
1,209 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 19
Past 30 Days: 76
All Time: 11,794
