Water Tap Perlator Replacement
  1. Water Tap Perlator Replacement, Loosen the tread: step 1, image 1 of 1
    • Loosen the perlator using some water pump pliers or an appropriate sized wrench.
    • Use some folded up paper shop towel to prevent the pliers scratching up the perlator, if you want to reuse it.
  2. Water Tap Perlator Replacement, Unscrew the perlator: step 2, image 1 of 2 Water Tap Perlator Replacement, Unscrew the perlator: step 2, image 2 of 2
    • Unscrew and remove the perlator by hand.
    • When screwing it on again just doing it finger tight will be alright, but you can also tighten it by following step one in reverse.
  3. Water Tap Perlator Replacement, Measure the tread diameter: step 3, image 1 of 1
    • Measure the outer diameter of the tread.
    • Common sizes would be M18, M20, M22, M24 and M28, with M24 being the most common of the bunch.
3 other people completed this guide.
Sebastian
31,308 Reputation
71 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 31
Past 30 Days: 123
All Time: 6,098
