Waterlogged Samsung Galaxy Grand Prime
  1. Waterlogged Samsung Galaxy Grand Prime, Waterlogged Samsung Galaxy Grand Prime: step 1, image 1 of 2 Waterlogged Samsung Galaxy Grand Prime, Waterlogged Samsung Galaxy Grand Prime: step 1, image 2 of 2
    • Power off your waterlogged Samsung Galaxy Grand Prime to prevent potential damage to the running circuitry
    • Place the phone with its screen facing the work surface
  2. Waterlogged Samsung Galaxy Grand Prime: step 2, image 1 of 3 Waterlogged Samsung Galaxy Grand Prime: step 2, image 2 of 3 Waterlogged Samsung Galaxy Grand Prime: step 2, image 3 of 3
    • Position the primary back panel towards you
    • Detach the primary back panel to expose the battery in the secondary back panel
  3. Waterlogged Samsung Galaxy Grand Prime: step 3, image 1 of 3 Waterlogged Samsung Galaxy Grand Prime: step 3, image 2 of 3 Waterlogged Samsung Galaxy Grand Prime: step 3, image 3 of 3
    • Using a 1.5x25 millimeter Phillips head screwdriver, remove the nine 4mm screws to gain access to the inner circuitry.
    • Put the screws to the side in order to avoid misplacement
  4. Waterlogged Samsung Galaxy Grand Prime: step 4, image 1 of 3 Waterlogged Samsung Galaxy Grand Prime: step 4, image 2 of 3 Waterlogged Samsung Galaxy Grand Prime: step 4, image 3 of 3
    • Remove the battery to prevent damage during the process
    • Gently peel up the battery and set it aside
  5. Waterlogged Samsung Galaxy Grand Prime: step 5, image 1 of 3 Waterlogged Samsung Galaxy Grand Prime: step 5, image 2 of 3 Waterlogged Samsung Galaxy Grand Prime: step 5, image 3 of 3
    • Carefully peel away the screen display from the secondary back panel
    • Use a hair dryer if needed to soften adhesive
  6. Waterlogged Samsung Galaxy Grand Prime: step 6, image 1 of 3 Waterlogged Samsung Galaxy Grand Prime: step 6, image 2 of 3 Waterlogged Samsung Galaxy Grand Prime: step 6, image 3 of 3
    • Address areas of concern in the main frame with a small towel or cotton swab
    • Submerging both parts in a container of desiccants like silica gel for a period of time can also be another option
  7. Waterlogged Samsung Galaxy Grand Prime: step 7, image 1 of 3 Waterlogged Samsung Galaxy Grand Prime: step 7, image 2 of 3 Waterlogged Samsung Galaxy Grand Prime: step 7, image 3 of 3
    • Make sure that there is no remaining liquid
    • Reassemble the phone, starting with the screen and secondary back panel
    • Press in on every side until the frame clicks into place
  8. Waterlogged Samsung Galaxy Grand Prime: step 8, image 1 of 3 Waterlogged Samsung Galaxy Grand Prime: step 8, image 2 of 3 Waterlogged Samsung Galaxy Grand Prime: step 8, image 3 of 3
    • Retrieve the battery set aside in step 4
    • Orient it correctly so the phone can properly boot up later
    • Carefully place the battery back into its slot
  9. Waterlogged Samsung Galaxy Grand Prime: step 9, image 1 of 3 Waterlogged Samsung Galaxy Grand Prime: step 9, image 2 of 3 Waterlogged Samsung Galaxy Grand Prime: step 9, image 3 of 3
    • Retrieve all of the 4mm screws you put aside in Step 3
    • Using the 1.5x25 millimeter Phillips head screwdriver, tighten all 9 of the 4mm screws
    • Confirm that each screw is sufficiently tightened to ensure stability and proper function
  10. Waterlogged Samsung Galaxy Grand Prime: step 10, image 1 of 3 Waterlogged Samsung Galaxy Grand Prime: step 10, image 2 of 3 Waterlogged Samsung Galaxy Grand Prime: step 10, image 3 of 3
    • Bring back the primary back panel from step 2
    • Align the primary back panel with the secondary back panel, ensuring the Samsung logo is facing outward
    • Click the panels together and work your way around until all sides are securely attached
  11. Waterlogged Samsung Galaxy Grand Prime: step 11, image 1 of 2 Waterlogged Samsung Galaxy Grand Prime: step 11, image 2 of 2
    • Charge the phone with a USB Micro-B cable so it has an initial charge when opening it back up
    • When all steps are performed correctly, the phone should power up and work as intended
Finish Line
3 other people completed this guide.
Johny Vu
241 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 31
All Time: 261
