Welch Allyn Connex Vital Signs Monitor 6000 Battery Replacement
Medical Equipment
Neither iFixit nor this repair guide is endorsed by or affiliated with the medical device manufacturer.
  1. Welch Allyn Connex Vital Signs Monitor 6000 Battery Replacement, Stand: step 1, image 1 of 2 Welch Allyn Connex Vital Signs Monitor 6000 Battery Replacement, Stand: step 1, image 2 of 2
    • Unplug the AC power connection cable.
  2. Welch Allyn Connex Vital Signs Monitor 6000 Battery Replacement: step 2, image 1 of 3 Welch Allyn Connex Vital Signs Monitor 6000 Battery Replacement: step 2, image 2 of 3 Welch Allyn Connex Vital Signs Monitor 6000 Battery Replacement: step 2, image 3 of 3
    • Place your thumb and forefinger on the blood pressure (NIBP) hose connector. Squeeze the side tabs until the connector releases.
    • Always grasp the hose by the connector. Do not pull on the hose itself.
    • Pull the connector away from the connector port.
  3. Welch Allyn Connex Vital Signs Monitor 6000 Battery Replacement: step 3, image 1 of 3 Welch Allyn Connex Vital Signs Monitor 6000 Battery Replacement: step 3, image 2 of 3 Welch Allyn Connex Vital Signs Monitor 6000 Battery Replacement: step 3, image 3 of 3
    • Place your thumb and forefinger on the Pulse oximetry (SpO2 or combined SpO2/SpHb) cable connector. Squeeze the side tabs until the connector releases.
    • Always grasp the cable by the connector. Do not pull on the cable itself.
  4. Welch Allyn Connex Vital Signs Monitor 6000 Battery Replacement: step 4, image 1 of 2 Welch Allyn Connex Vital Signs Monitor 6000 Battery Replacement: step 4, image 2 of 2
    • Grasp the temperature probe and pull it up to remove it from the monitor.
  5. Welch Allyn Connex Vital Signs Monitor 6000 Battery Replacement: step 5, image 1 of 3 Welch Allyn Connex Vital Signs Monitor 6000 Battery Replacement: step 5, image 2 of 3 Welch Allyn Connex Vital Signs Monitor 6000 Battery Replacement: step 5, image 3 of 3
    • Remove the cover of the temperature module by pressing the tab and sliding the cover to the right.
  6. Welch Allyn Connex Vital Signs Monitor 6000 Battery Replacement: step 6, image 1 of 3 Welch Allyn Connex Vital Signs Monitor 6000 Battery Replacement: step 6, image 2 of 3 Welch Allyn Connex Vital Signs Monitor 6000 Battery Replacement: step 6, image 3 of 3
    • Depress the spring tab on the temperature probe cable connector and withdraw it from the probe port.
  7. Welch Allyn Connex Vital Signs Monitor 6000 Battery Replacement: step 7, image 1 of 1
    • Remove the flathead screw on the USB networking door.
    • Loosen the captive Phillips #2 screw securing the monitor to the stand.
  8. Welch Allyn Connex Vital Signs Monitor 6000 Battery Replacement: step 8, image 1 of 1
    • Holding the monitor securely, open the USB networking door.
    • You may have to lift the monitor slightly to allow the door to swing out from the stand mount.
  9. Welch Allyn Connex Vital Signs Monitor 6000 Battery Replacement: step 9, image 1 of 2 Welch Allyn Connex Vital Signs Monitor 6000 Battery Replacement: step 9, image 2 of 2
    • Detach any accessory USB cables from USB ports on the monitor.
  10. Welch Allyn Connex Vital Signs Monitor 6000 Battery Replacement: step 10, image 1 of 3 Welch Allyn Connex Vital Signs Monitor 6000 Battery Replacement: step 10, image 2 of 3 Welch Allyn Connex Vital Signs Monitor 6000 Battery Replacement: step 10, image 3 of 3
    • Slide the monitor off of the stand tray.
  11. Welch Allyn Connex Vital Signs Monitor 6000 Battery Replacement, Battery: step 11, image 1 of 3 Welch Allyn Connex Vital Signs Monitor 6000 Battery Replacement, Battery: step 11, image 2 of 3 Welch Allyn Connex Vital Signs Monitor 6000 Battery Replacement, Battery: step 11, image 3 of 3
    • Place the monitor upside down on a clean surface.
    • Insert a coin into the slot and push to open.
    • Choose a coin that fits comfortably into the slot.
    • Remove the battery cover.
  12. Welch Allyn Connex Vital Signs Monitor 6000 Battery Replacement: step 12, image 1 of 3 Welch Allyn Connex Vital Signs Monitor 6000 Battery Replacement: step 12, image 2 of 3 Welch Allyn Connex Vital Signs Monitor 6000 Battery Replacement: step 12, image 3 of 3
    • Use the plastic label to remove the battery from its recess.
4 other people completed this guide.
kyle2
101 Reputation
1 Guide authored
Team Freedom Member of Team Freedom
Community
1 Member
3 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 16
All Time: 2,820
