Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement
  1. Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement, Stand: step 1, image 1 of 2 Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement, Stand: step 1, image 2 of 2
    • Unplug the AC power connection cable.
  2. Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement: step 2, image 1 of 3 Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement: step 2, image 2 of 3 Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement: step 2, image 3 of 3
    • Place your thumb and forefinger on the blood pressure (NIBP) hose connector. Squeeze the side tabs until the connector releases.
    • Always grasp the hose by the connector. Do not pull on the hose itself.
    • Pull the connector away from the connector port.
  3. Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement: step 3, image 1 of 3 Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement: step 3, image 2 of 3 Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement: step 3, image 3 of 3
    • Place your thumb and forefinger on the Pulse oximetry (SpO2 or combined SpO2/SpHb) cable connector. Squeeze the side tabs until the connector releases.
    • Always grasp the cable by the connector. Do not pull on the cable itself.
  4. Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement: step 4, image 1 of 2 Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement: step 4, image 2 of 2
    • Grasp the temperature probe and pull it up to remove it from the monitor.
  5. Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement: step 5, image 1 of 3 Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement: step 5, image 2 of 3 Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement: step 5, image 3 of 3
    • Remove the cover of the temperature module by pressing the tab and sliding the cover to the right.
  6. Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement: step 6, image 1 of 3 Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement: step 6, image 2 of 3 Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement: step 6, image 3 of 3
    • Depress the spring tab on the temperature probe cable connector and withdraw it from the probe port.
  7. Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement: step 7, image 1 of 1
    • Remove the flathead screw on the USB networking door.
    • Loosen the captive Phillips #2 screw securing the monitor to the stand.
  8. Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement: step 8, image 1 of 1
    • Holding the monitor securely, open the USB networking door.
    • You may have to lift the monitor slightly to allow the door to swing out from the stand mount.
  9. Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement: step 9, image 1 of 2 Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement: step 9, image 2 of 2
    • Detach any accessory USB cables from USB ports on the monitor.
  10. Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement: step 10, image 1 of 3 Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement: step 10, image 2 of 3 Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement: step 10, image 3 of 3
    • Slide the monitor off of the stand tray.
Sam Goldheart
467,232 Reputation
538 Guides authored
iFixit Member of iFixit
Staff
141 Members
17,903 Guides authored
One Comment
Can the stand itself be disassembled?
olajide bello - Reply
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 14
All Time: 894
