Welding technique: How to replace the joystick potentiometer
Video Overview
  1. Welding technique: How to replace the joystick potentiometer, Battery Pack: step 1, image 1 of 1
    • Remove the battery pack cover.
    • Remove batteries.
  2. Welding technique: How to replace the joystick potentiometer, Side Handles: step 2, image 1 of 2 Welding technique: How to replace the joystick potentiometer, Side Handles: step 2, image 2 of 2
    • We recommend using a nylon spudger for this step. A metal spudger is shown.
    • Grip the controller firmly to remove the side handles, wedging a spudger into the seam between the front and handle plates.
    • Pry the side plate away from the front plate by moving the spudger back and forth. You will need to do this all the way around the side plate's seam.
  3. Welding technique: How to replace the joystick potentiometer, Screws: step 3, image 1 of 2 Welding technique: How to replace the joystick potentiometer, Screws: step 3, image 2 of 2
    • There is a hidden screw located in the middle of the controller behind the label.
    • Use a screwdriver and punch a hole directly in the center of the label.
    • You may also lift the label if you do not want to puncture it.
    • Remove the five 10mm screws located on the back of the controller using the TR8 Security Torx Screwdriver.
  4. Welding technique: How to replace the joystick potentiometer, Backplate: step 4, image 1 of 1
    • Remove the backplate.
  5. Welding technique: How to replace the joystick potentiometer, Faceplate: step 5, image 1 of 1
    • Remove the faceplate.
  6. Welding technique: How to replace the joystick potentiometer, Top Motherboard: step 6, image 1 of 2 Welding technique: How to replace the joystick potentiometer, Top Motherboard: step 6, image 2 of 2
    • You may let the rumble motors hang freely out of their sockets.
    • De-solder the soldered joints while holding the red and black wires down on the top motherboard.
    • De-solder the black and gray wires that are attached to the top motherboard.
    • Remove the rumble motors and set them aside.
    • Be careful while using the soldering iron not to damage other components or hurt yourself.
    • For information on how to solder, click here.
  7. Welding technique: How to replace the joystick potentiometer: step 7, image 1 of 1
    • Unscrew the two 7mm T6 screws located near the rumble motor sockets.
  8. Welding technique: How to replace the joystick potentiometer: step 8, image 1 of 1
    • Firmly grip sides of motherboard near the middle.
    • Lift upwards while slightly wiggling the motherboard forward and backward.
    • Lifting the motherboard will require some force.
  9. Welding technique: How to replace the joystick potentiometer, Trigger Rumble Motors: step 9, image 1 of 1
    • Remove the yellow tape holding the wires in place on the front of the controller.
  10. Welding technique: How to replace the joystick potentiometer: step 10, image 1 of 3 Welding technique: How to replace the joystick potentiometer: step 10, image 2 of 3 Welding technique: How to replace the joystick potentiometer: step 10, image 3 of 3
    • Unscrew the two 7mm T6 Hex screws located on underside the triggers.
  11. Welding technique: How to replace the joystick potentiometer: step 11, image 1 of 1
    • Remove the trigger covers.
  12. Welding technique: How to replace the joystick potentiometer: step 12, image 1 of 1
    • Desolder the wires from the motherboard.
    • Remove the rumble motors from its socket and pull the wire with it.
  13. Welding technique: How to replace the joystick potentiometer, Bottom Motherboard: step 13, image 1 of 2 Welding technique: How to replace the joystick potentiometer, Bottom Motherboard: step 13, image 2 of 2
    • Remove the six T6 Torx screws located on the bottom motherboard.
  14. Welding technique: How to replace the joystick potentiometer: step 14, image 1 of 2 Welding technique: How to replace the joystick potentiometer: step 14, image 2 of 2
    • Remove the bumpers by prying them off of the pegs that secure them, using a spudger. They are located on the front and back of the controller.
    • A standard nylon spudger is recommended for this step. Using a metal spudger near the motherboard as shown risks damaging your device.
  15. Welding technique: How to replace the joystick potentiometer: step 15, image 1 of 2 Welding technique: How to replace the joystick potentiometer: step 15, image 2 of 2
    • Lift the piece surrounding the Home button off of its pegs.
    • Pry it off of the other side, using a spudger on the pins.
    • Removing this piece may require a lot of force.
  16. Welding technique: How to replace the joystick potentiometer: step 16, image 1 of 1
    • Remove the bottom motherboard.
3 other people completed this guide.
@HectorNavarroMX
3,994 Reputation
26 Guides authored
4 Comments
Do you know where we can get the original analogue module for the joystick?
Farhan Feroze - Reply
it does not exists, so you should buy generic replacement spare part
@HectorNavarroMX -
I love welding technics. This post has clear ideas on how to replace the joystick and shows in detail that’s I like it. I also try to fix many things, and it’s delightful. Thanks for sharing your ideas.
Anthony - Reply
I just created welding related blog and you will find here more: bestmigwelders.org
Anthony - Reply
Past 24 Hours: 6
Past 7 Days: 39
Past 30 Days: 147
All Time: 6,489
