Wen 2307 Power Cable Replacement
  1. Wen 2307 Power Cable Replacement, Front Panel: step 1, image 1 of 1
    • Unscrew the locking sleeve.
  2. Wen 2307 Power Cable Replacement: step 2, image 1 of 1
    • Remove the hanging clip.
  3. Wen 2307 Power Cable Replacement: step 3, image 1 of 2 Wen 2307 Power Cable Replacement: step 3, image 2 of 2
    • Unscrew the six 8mm PH2 screws.
  4. Wen 2307 Power Cable Replacement: step 4, image 1 of 1
    • While pressing the spindle lock button, unscrew the collet nut and remove it along with the brass collet.
  5. Wen 2307 Power Cable Replacement: step 5, image 1 of 1
    • To remove the front panel, pry the device apart while holding the device with the other hand.
    • The front panel should come out easily.
  6. Wen 2307 Power Cable Replacement, Power Cable: step 6, image 1 of 2 Wen 2307 Power Cable Replacement, Power Cable: step 6, image 2 of 2
    • Identify the screws.
    • Unscrew the two 3mm phillips PH2.
    • Don't forget to put them appart from the ones unscrewed before.
    • Phillips PH2
    • Flathead 2.5mm
  7. Wen 2307 Power Cable Replacement: step 7, image 1 of 1
    • Remove the place boar carefully.
  8. Wen 2307 Power Cable Replacement: step 8, image 1 of 1
    • Pull out the power cable connectors.
  9. Wen 2307 Power Cable Replacement: step 9, image 1 of 1
    • Pull out the cord sleve for the new cable replacement.
Sergio Palacio
437 Reputation
2 Guides authored
USF Tampa, Team 12-1, Eyestone Spring 2016 Member of USF Tampa, Team 12-1, Eyestone Spring 2016
USFT-EYESTONE-S16S12G1
4 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 6
All Time: 504
