Western Digital My Book Mini USB Port Replacement
  1. Western Digital My Book Mini USB Port Replacement, Mini USB Port: step 1, image 1 of 3 Western Digital My Book Mini USB Port Replacement, Mini USB Port: step 1, image 2 of 3 Western Digital My Book Mini USB Port Replacement, Mini USB Port: step 1, image 3 of 3
    • Start by turning the device port side up.
    • With the plastic opening tool, pry along the edges of the case.
    • When you hear the case snap-out of its fitted grooves, slowly slide the board assembly out of the case.
  2. Western Digital My Book Mini USB Port Replacement: step 2, image 1 of 1
    • Gently pull the three pronged, clear plastic piece from the rubber holder.
  3. Western Digital My Book Mini USB Port Replacement: step 3, image 1 of 1
    • Unscrew the two screws from the motherboard.
  4. Western Digital My Book Mini USB Port Replacement: step 4, image 1 of 1
    • Remove all the rubber pieces from the four corners to unhinge the motherboard.
  5. Western Digital My Book Mini USB Port Replacement: step 5, image 1 of 1
    • Remove the motherboard.
    • Set aside in a safe anti-static location.
  6. Western Digital My Book Mini USB Port Replacement: step 6, image 1 of 1
    • Grab the mini USB port and align it with the appropriate metal docks on the motherboard.
  7. Western Digital My Book Mini USB Port Replacement: step 7, image 1 of 1
    • Soldering irons can get HOT! Do not touch the iron tip, make sure it cools down for a good 30 minutes before touching the tip.
    • Start heating up the Soldering Iron, may take about 10–15 mins.
  8. Western Digital My Book Mini USB Port Replacement: step 8, image 1 of 1
    • Solder together the four corners of the mini USB to the appropriate metal pieces on the motherboard.
    • Make sure the USB is firmly attached to the motherboard.
To reassemble your device, follow these instructions in reverse order from step 8.
8 other people completed this guide.
Gabriel Rael
333 Reputation
1 Guide authored
Colorado Springs, Team 1-2, Mcmichael SU 2015 Member of Colorado Springs, Team 1-2, Mcmichael SU 2015
UCCS-MCMICHAEL-SU15S1G2
2 Members
2 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 19
Past 30 Days: 68
All Time: 18,041
