Wexford CT-166TF Plastic Casing Replacement
  1. Wexford CT-166TF Plastic Casing  Replacement, Settings Knob: step 1, image 1 of 1
    • Locate the knob at the top of the fan.
  2. Wexford CT-166TF Plastic Casing  Replacement: step 2, image 1 of 1
    • Remove the knob by gripping it and pulling straight up. Use a spudger if it is difficult to grip.
    • When reassembling, be sure to align the bottom of the new knob and the turning mechanism in the fan before pushing down.
  3. Wexford CT-166TF Plastic Casing  Replacement, Plastic Casing: step 3, image 1 of 1
    • Using the plastic opening tool, turn the device over and remove the black plastic covers over the four screw holes.
  4. Wexford CT-166TF Plastic Casing  Replacement: step 4, image 1 of 2 Wexford CT-166TF Plastic Casing  Replacement: step 4, image 2 of 2
    • Remove the four screws underneath the plastic covers.
  5. Wexford CT-166TF Plastic Casing  Replacement: step 5, image 1 of 2 Wexford CT-166TF Plastic Casing  Replacement: step 5, image 2 of 2
    • Remove 5 smaller screws visible through small holes between the base and the casing.
  6. Wexford CT-166TF Plastic Casing  Replacement: step 6, image 1 of 2 Wexford CT-166TF Plastic Casing  Replacement: step 6, image 2 of 2
    • Remove four screws on the back, two near the top and two near the bottom.
  7. Wexford CT-166TF Plastic Casing  Replacement: step 7, image 1 of 1
    • Pull off the back casing.
  8. Wexford CT-166TF Plastic Casing  Replacement: step 8, image 1 of 2 Wexford CT-166TF Plastic Casing  Replacement: step 8, image 2 of 2
    • Remove the 2 screws that attach the front part of the casing to the motor.
  9. Wexford CT-166TF Plastic Casing  Replacement: step 9, image 1 of 2 Wexford CT-166TF Plastic Casing  Replacement: step 9, image 2 of 2
    • Remove the two middle screws attaching the black plastic cover to the front .
  10. Wexford CT-166TF Plastic Casing  Replacement: step 10, image 1 of 1
    • Remove the two screws attached to the white bar near the red light on the top of the front casing.
  11. Wexford CT-166TF Plastic Casing  Replacement: step 11, image 1 of 1
    • Remove the two screws keeping the button attached to the top of the casing.
Cameron Mattson
101 Reputation
1 Guide authored
UW Tacoma, Team S3-G4, Liner Spring 2017 Member of UW Tacoma, Team S3-G4, Liner Spring 2017
UWT-LINER-S17S3G4
4 Members
3 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 12
All Time: 516
