Whirlpool Refrigerator Door Sensor Replacement
  1. Whirlpool Refrigerator Door Sensor Replacement, Open the doors: step 1, image 1 of 3 Whirlpool Refrigerator Door Sensor Replacement, Open the doors: step 1, image 2 of 3 Whirlpool Refrigerator Door Sensor Replacement, Open the doors: step 1, image 3 of 3
    • Depending on your repair, open one or both doors.
  2. Whirlpool Refrigerator Door Sensor Replacement, Unclip the door sensor: step 2, image 1 of 3 Whirlpool Refrigerator Door Sensor Replacement, Unclip the door sensor: step 2, image 2 of 3 Whirlpool Refrigerator Door Sensor Replacement, Unclip the door sensor: step 2, image 3 of 3
    • Insert a flathead screwdriver, or a similar tool, between the door sensor and the chassis.
    • Pry up to separate the door sensor enough so you can grip it with your fingers.
  3. Whirlpool Refrigerator Door Sensor Replacement, Remove the door sensor: step 3, image 1 of 2 Whirlpool Refrigerator Door Sensor Replacement, Remove the door sensor: step 3, image 2 of 2
    • Pull the door sensor through the chassis enough to access its connectors.
    • Disconnect any connectors attached to the door sensor.
    • Remove the door sensor.
  4. Whirlpool Refrigerator Door Sensor Replacement, Meter the door sensor: step 4, image 1 of 2 Whirlpool Refrigerator Door Sensor Replacement, Meter the door sensor: step 4, image 2 of 2
    • If you own a multimeter, you can test your door sensor's resistance.
    • Set the multimeter to the resistance or continuity measurement mode.
    • With the button in its neutral position, the multimeter should read "OL."
    • With the button pressed, the multimeter should read around 0Ω.
Repair didn’t go as planned? Ask our Answers community for help.
nicO
15,927 Reputation
88 Guides authored
Global Fixers Member of Global Fixers
Community
35 Members
603 Guides authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 21
Past 30 Days: 137
All Time: 2,080
