Why! NH57ADS Bottom Case Replacement
  1. Why! NH57ADS Bottom Case Replacement, Battery: step 1, image 1 of 3 Why! NH57ADS Bottom Case Replacement, Battery: step 1, image 2 of 3 Why! NH57ADS Bottom Case Replacement, Battery: step 1, image 3 of 3
    • Remove the two screws holding the battery in place.
    • Slip your finger into the finger hole provided at the top of the battery and lift to remove it.
  2. Why! NH57ADS Bottom Case Replacement, Bottom Cover: step 2, image 1 of 3 Why! NH57ADS Bottom Case Replacement, Bottom Cover: step 2, image 2 of 3 Why! NH57ADS Bottom Case Replacement, Bottom Cover: step 2, image 3 of 3
    • Remove the five Phillips screws securing the bottom to the case.
    • Slide the cover up slightly to release the catches holding it in place. This is the view on the right. The mark on the cover should now line up with the second mark on the case of the computer.
  3. Why! NH57ADS Bottom Case Replacement, Removing the Bottom Cover: step 3, image 1 of 3 Why! NH57ADS Bottom Case Replacement, Removing the Bottom Cover: step 3, image 2 of 3 Why! NH57ADS Bottom Case Replacement, Removing the Bottom Cover: step 3, image 3 of 3
    • This is the view on the left before and after sliding the cover. The mark on the cover should now line up with the second mark on the case of the computer.
    • Lift the bottom cover to remove it.
  4. Why! NH57ADS Bottom Case Replacement, Keyboard: step 4, image 1 of 3 Why! NH57ADS Bottom Case Replacement, Keyboard: step 4, image 2 of 3 Why! NH57ADS Bottom Case Replacement, Keyboard: step 4, image 3 of 3
    • Remove the two Phillips screws with the keypad symbol next to them.
    • Insert an opening pick into the upper slot of the keyboard and slide it to the end.
  5. Why! NH57ADS Bottom Case Replacement, Remove the Keyboard: step 5, image 1 of 3 Why! NH57ADS Bottom Case Replacement, Remove the Keyboard: step 5, image 2 of 3 Why! NH57ADS Bottom Case Replacement, Remove the Keyboard: step 5, image 3 of 3
    • Carefully lift the keyboard.
    • Flip up the retaining latch on the black keyboard cable and slide it out of the connector.
    • Repeat with the orange backlight cable.
  6. Why! NH57ADS Bottom Case Replacement, Fan: step 6, image 1 of 3 Why! NH57ADS Bottom Case Replacement, Fan: step 6, image 2 of 3 Why! NH57ADS Bottom Case Replacement, Fan: step 6, image 3 of 3
    • Remove the three Phillips screws securing the fan on the right.
    • Carefully unplug the fan's power connector.
    • Remove the first fan.
  7. Why! NH57ADS Bottom Case Replacement, Fan and Heatsink Assembly: step 7, image 1 of 3 Why! NH57ADS Bottom Case Replacement, Fan and Heatsink Assembly: step 7, image 2 of 3 Why! NH57ADS Bottom Case Replacement, Fan and Heatsink Assembly: step 7, image 3 of 3
    • Remove the two Phillips screws securing the left hand fan.
    • Remove the six Phillips heatsink retaining screws .
    • Using the two black tabs as handles, lift and remove the heatsink.
  8. Why! NH57ADS Bottom Case Replacement, CPU: step 8, image 1 of 3 Why! NH57ADS Bottom Case Replacement, CPU: step 8, image 2 of 3 Why! NH57ADS Bottom Case Replacement, CPU: step 8, image 3 of 3
    • Carefully pull the metal bar away from the processor to free it from under the retaining tab, then lift it to release the processor pins.
    • Gently remove the processor by lifting it straight up.
  9. Why! NH57ADS Bottom Case Replacement, Bottom Case: step 9, image 1 of 3 Why! NH57ADS Bottom Case Replacement, Bottom Case: step 9, image 2 of 3 Why! NH57ADS Bottom Case Replacement, Bottom Case: step 9, image 3 of 3
    • Remove the 12 Phillips screws securing the bottom case.
    • Using an opening pick, detach the lower case.
To reassemble your device, follow the instructions in reverse order.
Special thanks to these translators:
fr en
100%
Jerry Wheeler is helping us fix the world! Want to contribute?
Start translating ›
Felice Suglia
31,100 Reputation
264 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 49
