Why! NV41MZ Right Speaker Replacement
  1. Why! NV41MZ Right Speaker Replacement, Bottom Cover: step 1, image 1 of 3 Why! NV41MZ Right Speaker Replacement, Bottom Cover: step 1, image 2 of 3 Why! NV41MZ Right Speaker Replacement, Bottom Cover: step 1, image 3 of 3
    • Remove the 14 screws securing the bottom case to the laptop.
    • Unclip the case by sliding a plastic spudger into the slots in the case.
    • Remove the bottom case.
  2. Why! NV41MZ Right Speaker Replacement, Remove the SSD: step 2, image 1 of 2 Why! NV41MZ Right Speaker Replacement, Remove the SSD: step 2, image 2 of 2
    • Remove the Phillips screw securing the SSD.
    • The SSD board will pop up slightly once the screw is removed. Lift it to relieve any tension and pull it straight out.
  3. Why! NV41MZ Right Speaker Replacement, Battery: step 3, image 1 of 2 Why! NV41MZ Right Speaker Replacement, Battery: step 3, image 2 of 2
    • Remove the five Phillips screws securing the battery.
    • Unplug the cable connecting the battery to the motherboard.
    • Remove the battery.
  4. Why! NV41MZ Right Speaker Replacement, Right Speaker: step 4, image 1 of 3 Why! NV41MZ Right Speaker Replacement, Right Speaker: step 4, image 2 of 3 Why! NV41MZ Right Speaker Replacement, Right Speaker: step 4, image 3 of 3
    • Remove the CMOS battery by carefully peeling it off.
    • Unscrew the 2 speaker screws.
    • Peel off the adhesive strip using an opening pick or spudger.
  5. Why! NV41MZ Right Speaker Replacement, Remove the Speaker: step 5, image 1 of 1
    • Disconnect the speaker cable from the motherboard.
    • Remove the speaker.
To reassemble your device, follow the instructions in reverse order.
Special thanks to these translators:
fr en
100%
Jerry Wheeler is helping us fix the world! Want to contribute?
Start translating ›
Felice Suglia
31,100 Reputation
264 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 53
