Why! NV41MZ SSD Replacement
  1. Why! NV41MZ SSD Replacement, Bottom Cover: step 1, image 1 of 3 Why! NV41MZ SSD Replacement, Bottom Cover: step 1, image 2 of 3 Why! NV41MZ SSD Replacement, Bottom Cover: step 1, image 3 of 3
    • Remove the 14 screws securing the bottom case to the laptop.
    • Unclip the case by sliding a plastic spudger into the slots in the case.
    • Remove the bottom case.
  2. Why! NV41MZ SSD Replacement, Remove the SSD: step 2, image 1 of 2 Why! NV41MZ SSD Replacement, Remove the SSD: step 2, image 2 of 2
    • Remove the Phillips screw securing the SSD.
    • The SSD board will pop up slightly once the screw is removed. Lift it to relieve any tension and pull it straight out.
To reassemble your device, follow the instructions in reverse order.
Special thanks to these translators:
fr en
100%
Jerry Wheeler is helping us fix the world! Want to contribute?
Start translating ›
Felice Suglia
31,100 Reputation
264 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 5
All Time: 242
