Wii Balance Board Back Cover Replacement
  1. Wii Balance Board Back Cover Replacement, Unscrewing the Foot Cover: step 1, image 1 of 1
    • Flip device upside-down so the plastic white board is facing the ground.
    • Locate the four feet in the corners of the Balance Board.
    • Unscrew the three 12.7 mm Phillips screws from each foot cover.
  2. Wii Balance Board Back Cover Replacement, Removing the Foot Cover: step 2, image 1 of 1
    • Remove the gray plastic ring from the actual foot by lifting it up.
  3. Wii Balance Board Back Cover Replacement, Removing the Foot: step 3, image 1 of 1
    • Separate the loose foot from the device by lifting it up.
  4. Wii Balance Board Back Cover Replacement, Removing the Additional Feet: step 4, image 1 of 1
    • Repeat steps two and three on the remaining four feet.
  5. Wii Balance Board Back Cover Replacement, Unscrewing the Back Cover: step 5, image 1 of 1
    • Unscrew the ten 12.7 mm Phillips #1 screws.
  6. Wii Balance Board Back Cover Replacement, Removing the Back Cover: step 6, image 1 of 1
    • Lift off the gray back cover.
Cory Olson
936 Reputation
4 Guides authored
Cal Poly, Team 13-8, Forte Fall 2014 Member of Cal Poly, Team 13-8, Forte Fall 2014
CPSU-FORTE-F14S13G8
5 Members
16 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 17
All Time: 1,480
