Wii Balance Board Foot Replacement
  1. Wii Balance Board Foot Replacement, Unscrewing the Foot Cover: step 1, image 1 of 1
    • Flip device upside-down so the plastic white board is facing the ground.
    • Locate the four feet in the corners of the Balance Board.
    • Unscrew the three 12.7 mm Phillips screws from each foot cover.
  2. Wii Balance Board Foot Replacement, Removing the Foot Cover: step 2, image 1 of 1
    • Remove the gray plastic ring from the actual foot by lifting it up.
  3. Wii Balance Board Foot Replacement, Removing the Foot: step 3, image 1 of 1
    • Separate the loose foot from the device by lifting it up.
  4. Wii Balance Board Foot Replacement, Removing the Additional Feet: step 4, image 1 of 1
    • Repeat steps two and three on the remaining four feet.
Cory Olson
939 Reputation
4 Guides authored
Cal Poly, Team 13-8, Forte Fall 2014 Member of Cal Poly, Team 13-8, Forte Fall 2014
CPSU-FORTE-F14S13G8
5 Members
16 Guides authored
2 Guide Comments
I am in need of a foot cover. Where can I find one??
Marvin Hopper - Reply Share
This manual did not help
nbrown1959.nb - Reply Share
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 79
All Time: 3,764
