Wii Balance Board Frame Replacement
  1. Wii Balance Board Frame Replacement, Unscrewing the Foot Cover: step 1, image 1 of 1
    • Flip device upside-down so the plastic white board is facing the ground.
    • Locate the four feet in the corners of the Balance Board.
    • Unscrew the three 12.7 mm Phillips screws from each foot cover.
  2. Wii Balance Board Frame Replacement, Removing the Foot Cover: step 2, image 1 of 1
    • Remove the gray plastic ring from the actual foot by lifting it up.
  3. Wii Balance Board Frame Replacement, Removing the Foot: step 3, image 1 of 1
    • Separate the loose foot from the device by lifting it up.
  4. Wii Balance Board Frame Replacement, Removing the Additional Feet: step 4, image 1 of 1
    • Repeat steps two and three on the remaining four feet.
  5. Wii Balance Board Frame Replacement, Unscrewing the Back Cover: step 5, image 1 of 1
    • Unscrew the ten 12.7 mm Phillips #1 screws.
  6. Wii Balance Board Frame Replacement, Removing the Back Cover: step 6, image 1 of 1
    • Lift off the gray back cover.
  7. Wii Balance Board Frame Replacement, Battery Compartment: step 7, image 1 of 2 Wii Balance Board Frame Replacement, Battery Compartment: step 7, image 2 of 2
    • Locate the gray battery compartment.
    • Push the tab on the bottom and lift up completely to remove the cover to the batteries.
  8. Wii Balance Board Frame Replacement, Removing the Battery Case: step 8, image 1 of 1
    • Unscrew the two 6.35 mm Phillips #1 screws.
    • Slide the battery case out.
  9. Wii Balance Board Frame Replacement, Unscrewing the Frame: step 9, image 1 of 1
    • Unscrew the four 12.7 mm #1 screws.
  10. Wii Balance Board Frame Replacement, Removing the Frame: step 10, image 1 of 1
    • Lift the frame, circuit board, and power supply out of the front case. These components are all connected.
  11. Wii Balance Board Frame Replacement, Removing the Power Supply: step 11, image 1 of 1
    • Lift out the power supply. It is not screwed in.
Cory Olson
936 Reputation
4 Guides authored
Cal Poly, Team 13-8, Forte Fall 2014 Member of Cal Poly, Team 13-8, Forte Fall 2014
CPSU-FORTE-F14S13G8
5 Members
16 Guides authored
2 Guide Comments
Top Anleitung, aber wo kann ich die Platine herbekommen? Danke!!!
Dominik - Reply
Hi, My batteries leaked over the UART_RX pin and I don't know how to fix it
Julián Rodríguez - Reply
Past 24 Hours: 5
Past 7 Days: 18
Past 30 Days: 57
All Time: 4,041
