Wii U GamePad Outer Case Replacement
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
  1. Wii U GamePad Outer Case Replacement, Battery: step 1, image 1 of 1
    • Place Gamepad face down and remove the two 4.7 mm screws with a Phillips size #00 screwdriver.
  2. Wii U GamePad Outer Case Replacement: step 2, image 1 of 1
    • Lift and remove the battery plate.
  3. Wii U GamePad Outer Case Replacement: step 3, image 1 of 3 Wii U GamePad Outer Case Replacement: step 3, image 2 of 3 Wii U GamePad Outer Case Replacement: step 3, image 3 of 3
    • With your finger, press down and pull back on the battery connector plug.
    • Remove the battery from the battery case.
  4. Wii U GamePad Outer Case Replacement, Outer Case: step 4, image 1 of 3 Wii U GamePad Outer Case Replacement, Outer Case: step 4, image 2 of 3 Wii U GamePad Outer Case Replacement, Outer Case: step 4, image 3 of 3
    • Remove 10 9mm screws with Tri-Wing size Y1 screwdriver around the outer case.
    • Lift up on the back of case.
    • Lift gently because the rumble motor in the back of the case is still connected by a cable to the motherboard.
  5. Wii U GamePad Outer Case Replacement: step 5, image 1 of 1
    • Unplug outer case rumble motor connector from the motherboard with your fingers.
    • Do not pull on the wires as shown in this picture, they will likely break off. Pull directly on the plug (NOT the receptacle)
5 other people completed this guide.
Valentina Cerruty
3,450 Reputation
7 Guides authored
USF Tampa, Team 1-6, Sullivan Spring 2016 Member of USF Tampa, Team 1-6, Sullivan Spring 2016
USFT-SULLIVAN-S16S1G6
4 Members
40 Guides authored
2 Comments
This doesn't show anything about taking the front of the housing off, is that relatively straightforward?
Will Prosser - Reply
This doesn't show anything about the L and R sticks like moving on its own when i play, do you how to fix that?
Victoria Gonzalez - Reply
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 37
All Time: 7,045
