Wiko Getaway Screen Panel Replacement
Video Overview
  1. Wiko Getaway Screen Panel Replacement, Back cover: step 1, image 1 of 3 Wiko Getaway Screen Panel Replacement, Back cover: step 1, image 2 of 3 Wiko Getaway Screen Panel Replacement, Back cover: step 1, image 3 of 3
    • Broken screen ? that's a pity
    • You'll need hot air. Not too much thought, you'll melt the plastic otherwise
    • Now just pry it open SLOWLY and apply heat.
  2. Wiko Getaway Screen Panel Replacement, Disconnect stuff: step 2, image 1 of 3 Wiko Getaway Screen Panel Replacement, Disconnect stuff: step 2, image 2 of 3 Wiko Getaway Screen Panel Replacement, Disconnect stuff: step 2, image 3 of 3
    • Nice, I see you've got the cover off
    • Disconnect the battery (not with a metal tool)
    • Disconnect the touch screen ribbon (don't pull hard, you have to lift the plastic bit before)
  3. Wiko Getaway Screen Panel Replacement, Disconnecting more stuff: step 3, image 1 of 3 Wiko Getaway Screen Panel Replacement, Disconnecting more stuff: step 3, image 2 of 3 Wiko Getaway Screen Panel Replacement, Disconnecting more stuff: step 3, image 3 of 3
    • Get the battery out (don't bend it too much)
    • Disconnect the LCD ribbon
    • Disconnect the cameras
  4. Wiko Getaway Screen Panel Replacement, Screws ! Finally: step 4, image 1 of 3 Wiko Getaway Screen Panel Replacement, Screws ! Finally: step 4, image 2 of 3 Wiko Getaway Screen Panel Replacement, Screws ! Finally: step 4, image 3 of 3
    • Unscrew anything you see
    • Take the SIM trays out
    • Take the motherboard out. You will have to disconnect to ribbon cables
  5. Wiko Getaway Screen Panel Replacement, Final: step 5, image 1 of 3 Wiko Getaway Screen Panel Replacement, Final: step 5, image 2 of 3 Wiko Getaway Screen Panel Replacement, Final: step 5, image 3 of 3
    • Two screws here
    • To take this guy out, you can use heat again
    • Aaaaand with more heat, you will get the screen panel out !
4 other people completed this guide.
Alexandre Isaac
3,075 Reputation
8 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 19
All Time: 2,433
