Wiko Rainbow Jam 4G Display Replacement
  1. Wiko Rainbow Jam 4G Display Replacement, Display: step 1, image 1 of 2 Wiko Rainbow Jam 4G Display Replacement, Display: step 1, image 2 of 2
    • Remove the back cover and the battery
  2. Wiko Rainbow Jam 4G Display Replacement: step 2, image 1 of 3 Wiko Rainbow Jam 4G Display Replacement: step 2, image 2 of 3 Wiko Rainbow Jam 4G Display Replacement: step 2, image 3 of 3
    • Using a Phillips scredriver, remove the screws
    • Using a thin tool or a blade detach the midframe from the the display assembly
  3. Wiko Rainbow Jam 4G Display Replacement: step 3, image 1 of 3 Wiko Rainbow Jam 4G Display Replacement: step 3, image 2 of 3 Wiko Rainbow Jam 4G Display Replacement: step 3, image 3 of 3
    • Remove the sticker with a heat source, for example using a hair dryer
    • Unplug the marked connector on the motherboard
    • Remove the stickers that holds the flat under the big sticker you removed earlier. Now remove the marked screw that keeps the motherboard in place
  4. Wiko Rainbow Jam 4G Display Replacement: step 4, image 1 of 3 Wiko Rainbow Jam 4G Display Replacement: step 4, image 2 of 3 Wiko Rainbow Jam 4G Display Replacement: step 4, image 3 of 3
    • Lift the motherboard and unplug the antenna cable
    • Using heat and a blade, remove the adesive holding the volume/power button
    • Remove the motherboard
  5. Wiko Rainbow Jam 4G Display Replacement: step 5, image 1 of 1
    • Remove the flat cable interconnecting the display and the motherboard. It's glued on the back of the frame.
  6. Wiko Rainbow Jam 4G Display Replacement: step 6, image 1 of 3 Wiko Rainbow Jam 4G Display Replacement: step 6, image 2 of 3 Wiko Rainbow Jam 4G Display Replacement: step 6, image 3 of 3
    • Heat the display edges to soften the glue. Gradually insert a thin blade to remove the faulty display.
    • Remove the old adhesive and clean carefully the surface before you apply the new adhesive.
  7. Wiko Rainbow Jam 4G Display Replacement: step 7, image 1 of 3 Wiko Rainbow Jam 4G Display Replacement: step 7, image 2 of 3 Wiko Rainbow Jam 4G Display Replacement: step 7, image 3 of 3
    • Apply the double sided tape on the edges of the frame so the enclosure is ready for a new display.
Special thanks to these translators:
it en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Smilzo
11,447 Reputation
39 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 10
All Time: 516
