Wiko pulp 4g Touch screen Replacement
  1. Wiko pulp 4g Touch screen Replacement, Touch screen: step 1, image 1 of 2 Wiko pulp 4g Touch screen Replacement, Touch screen: step 1, image 2 of 2
    • Remove back cover
    • Remove battery
  2. Wiko pulp 4g Touch screen Replacement: step 2, image 1 of 1
    • remove the screws marked, attention is covered by a white sticker
  3. Wiko pulp 4g Touch screen Replacement: step 3, image 1 of 2 Wiko pulp 4g Touch screen Replacement: step 3, image 2 of 2
    • using a thin tool separate the middle frame from the body display
  4. Wiko pulp 4g Touch screen Replacement: step 4, image 1 of 2 Wiko pulp 4g Touch screen Replacement: step 4, image 2 of 2
    • unhook touchscreen connector
  5. Wiko pulp 4g Touch screen Replacement: step 5, image 1 of 3 Wiko pulp 4g Touch screen Replacement: step 5, image 2 of 3 Wiko pulp 4g Touch screen Replacement: step 5, image 3 of 3
    • Remove 2 screws securing the motherboard
    • Unfasten the connectors
    • remove front and rear cameras
  6. Wiko pulp 4g Touch screen Replacement: step 6, image 1 of 3 Wiko pulp 4g Touch screen Replacement: step 6, image 2 of 3 Wiko pulp 4g Touch screen Replacement: step 6, image 3 of 3
    • Unhook cable connection between top and bottom card
    • remove top motherboard
  7. Wiko pulp 4g Touch screen Replacement: step 7, image 1 of 3 Wiko pulp 4g Touch screen Replacement: step 7, image 2 of 3 Wiko pulp 4g Touch screen Replacement: step 7, image 3 of 3
    • Heat the phone with a 80-degree plate or with an appropriate dryer
    • With the help of tools or special thin wire begin to separate from the touch glass display
    • Utmost care not to break the display, be sure to insert between the touch screen display instruments and not between glass and touch screen ..
    • There are no flat key is therefore the only attention to the display
  8. Wiko pulp 4g Touch screen Replacement: step 8, image 1 of 2 Wiko pulp 4g Touch screen Replacement: step 8, image 2 of 2
    • Clean the display from the sticky residue
    • applying adhesive on the edges and the new touchscreen glass
To assemble the device, follow these instructions in reverse order.
8 other people completed this guide.
Special thanks to these translators:
it en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Smilzo
11,447 Reputation
39 Guides authored
4 Comments
I replaced a screen on a Acer Wiko Lenny 2 - was very simular to this one. I followed all these steps and it is working BUT the display does not respond as it should. Almost all touches on the outside border of the screen (for example, digit 1 on the left, digit 0 on the right) don't respond quickly, or don't respond at all. What could be wrong? If wonder if I didn't clean the digitizer properly enough...
Jan Oelbrandt - Reply
sorry for the delay.
I had some problem with the touch screen too much more intrusive than yours.
I have secured the edges well with scotch because it does not contact me.
But these Chinese touchscreens do not have good quality so I prefer to buy a screen mounted with touchscreen, so I save a lot of time and work is better and working
Smilzo - Reply
Ciao, come fai a rimuovere i residui di colla dal display, una volta tolto il vetro?
Roberto Oboe - Reply
Scaldando e con una spatolina ed anche con il puliscicontatti spray
Smilzo - Reply
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 14
All Time: 7,501
