Wiko pulp 4g Touchscreen and display Replacement
  1. Wiko pulp 4g Touchscreen and display Replacement, Touch screen: step 1, image 1 of 2 Wiko pulp 4g Touchscreen and display Replacement, Touch screen: step 1, image 2 of 2
    • Remove back cover
    • Remove battery
  2. Wiko pulp 4g Touchscreen and display Replacement: step 2, image 1 of 1
    • remove the screws marked, attention is covered by a white sticker
  3. Wiko pulp 4g Touchscreen and display Replacement: step 3, image 1 of 2 Wiko pulp 4g Touchscreen and display Replacement: step 3, image 2 of 2
    • using a thin tool separate the middle frame from the body display
  4. Wiko pulp 4g Touchscreen and display Replacement: step 4, image 1 of 2 Wiko pulp 4g Touchscreen and display Replacement: step 4, image 2 of 2
    • unhook touchscreen connector
  5. Wiko pulp 4g Touchscreen and display Replacement: step 5, image 1 of 3 Wiko pulp 4g Touchscreen and display Replacement: step 5, image 2 of 3 Wiko pulp 4g Touchscreen and display Replacement: step 5, image 3 of 3
    • Remove 2 screws securing the motherboard
    • Unfasten the connectors
    • remove front and rear cameras
  6. Wiko pulp 4g Touchscreen and display Replacement: step 6, image 1 of 3 Wiko pulp 4g Touchscreen and display Replacement: step 6, image 2 of 3 Wiko pulp 4g Touchscreen and display Replacement: step 6, image 3 of 3
    • Unhook cable connection between top and bottom card
    • remove top motherboard
  7. Wiko pulp 4g Touchscreen and display Replacement: step 7, image 1 of 3 Wiko pulp 4g Touchscreen and display Replacement: step 7, image 2 of 3 Wiko pulp 4g Touchscreen and display Replacement: step 7, image 3 of 3
    • Heat the phone with a 80-degree plate or with an appropriate dryer
    • With the help of tools or special thin wire begin to separate from the touch glass display
    • Utmost care not to break the display, be sure to insert between the touch screen display instruments and not between glass and touch screen ..
    • There are no flat key is therefore the only attention to the display
  8. Wiko pulp 4g Touchscreen and display Replacement: step 8, image 1 of 2 Wiko pulp 4g Touchscreen and display Replacement: step 8, image 2 of 2
    • Clean the display from the sticky residue
    • applying adhesive on the edges and the new touchscreen glass
  9. Wiko pulp 4g Touchscreen and display Replacement, Touchscreen and display: step 9, image 1 of 2 Wiko pulp 4g Touchscreen and display Replacement, Touchscreen and display: step 9, image 2 of 2
    • Follow the guide "replace touchscreen" until the 6 step, and jump the step 7 & 8.
    • With an heat gun or an other source of heat to pull off the adhesive holding down the battery.
    • With the battery removed applied another bit of heat gun to remove the Flat Display
  10. Wiko pulp 4g Touchscreen and display Replacement: step 10, image 1 of 1
    • With heat and and an small ESD tweezers lift the glass from the frame and extract touch screen and display from the phone body
To assemble the device, follow these instructions in reverse order.
11 other people completed this guide.
Special thanks to these translators:
it en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Smilzo
11,447 Reputation
39 Guides authored
3 Comments
Bravo ottima guida
David Moga - Reply
Ti ringrazio, mi fa piacere se torna utile a qualcuno. Saluti
Smilzo -
Ciao Raffaele,il touch lo trovi a 15€ io ne avevo preso uno che poi mi hanno sostituito per il wiko del mio amico ma entrambi erano difettosi,con tanta pazienza prima di prenderli ero riuscito a salvare il display dal distaccamento del touch rotto.
naturalmente senza incollarlo al centro(ancora non avevo li strumenti) non aderendo bene ed essendo un display grande il vetro sottile flette quai di il risultato è che tocca il display e lo sente come un tocco quindi non è gestibile molto bene anche spessorandolo i bordi poi facevano fatica ad avere sensibilità.
cmq avevo trovato il gruppo completo sotto le 50€ Ed ho deciso di fare la sostituzione completa e poi è andato tutto ok.
valuta un po’ insieme al tuo tecnico,ma il problema che sostituire il touch richiede molta manodopera per avere un pessimo lavoro e finché lo fai tu a perditempo va bene ma se devi pagare qualcuno conviene assolutamente comprare il gruppo completo.istallazione rapida ed indolore con risultato ottimo.
saluti
Smilzo - Reply
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 15
All Time: 8,569
