Wind-up carriage clock Service clean
  1. Wind-up carriage clock Service clean, Naming of Parts: step 1, image 1 of 1
    • Clockmakers (horologists) have their own jargon which we will stick to, as this is the terminology you will come across if you seek help and guidance elsewhere.
    • The spindle on which a gear is mounted is known as an arbor.
    • At each end of an arbor is generally a thinner section. This is known as a pivot, which engages in a pivot hole to form a bearing.
    • A small gear is known as a pinion.
    • A larger gear is known as a wheel. A wheel frequently engages with a pinion to form a reduction gear. Several such together form a gear train, transmitting the power of the spring to the escapement and the hands.
    • A wheel and a pinion are always mounted on parallel arbors, however, a contrate wheel (like a crown) can engage with a pinion on an arbor at right angles.
  2. Wind-up carriage clock Service clean, Unwinding the spring: step 2, image 1 of 1
    • On no account omit this step!
    • While holding the spring tension with the winding key, release the ratchet.
    • Still keeping a firm hold on the winding key, allow the spring to unwind in a controlled manner by 180 degrees, or only as much as the rotation of your wrist will allow.
    • Re-engage the ratchet while you prepare to repeat the process.
    • Repeat until there is no tension left in the spring.
  3. Wind-up carriage clock Service clean, Loosening the base screws: step 3, image 1 of 2 Wind-up carriage clock Service clean, Loosening the base screws: step 3, image 2 of 2
    • Before starting disassembly it's a good idea to wrap a length of sticky tape around the front and two sides of the clock towards the bottom, from one rear pillar to the other, to prevent the front and side glasses falling out as you remove the case.
    • Turn the clock over and peal back the felt covering the base at each corner, to reveal the holes for the screws holding the four brass case pillars to the base.
    • With a suitable screwdriver, loosen all four screws just a little. They may initially be fairly tight. Do not let the screwdriver slip in the screw heads. Do not remove the screws just yet.
  4. Wind-up carriage clock Service clean, Removing the read door: step 4, image 1 of 2 Wind-up carriage clock Service clean, Removing the read door: step 4, image 2 of 2
    • Loosen the screws until you can separate the case from the base by just a few millimetres. You should then be able to remove the back door.
    • The back door has a pin in the top engaging with the top of the clock and a pin in the bottom engaging with the base. These are liable to fall out and get lost. Stow them somewhere safe.
  5. Wind-up carriage clock Service clean, Removing the case: step 5, image 1 of 1
    • The three glass panels fit into slots in the vertical pillars. Despite the tape you applied in the previous step, there is some risk they may fall out as you release the case from the base. If so, they may crack or get chipped. Replacement glass panels with their bevelled edges might be hard to source.
    • With the clock on its face and if possible, holding the case to ensure that the vertical pillars hold the glass panels, remove all four screws in the base and remove the base.
    • Check to see whether any of the glass panels is now loose and at risk of falling out. If so, carefully remove it and put it aside. Put the case aside standing upright, so that at worst, the glass panels can only slip down in their grooves until they are resting on the table.
    • If any of the glass panels come out you may well find thin plastic strips in the grooves to take up any slack and so that the glass doesn't bear directly on the brass of the pillars. Take care not to lose these strips.
    • On reassembly, if any of the glass panels and their plastic strips came out, ensure that the strips are at the far ends of the grooves from the base otherwise you may not be able to get all the screws in the base to engage with the threaded holes in the pillars.
  6. Wind-up carriage clock Service clean, Detaching the movement from the base: step 6, image 1 of 3 Wind-up carriage clock Service clean, Detaching the movement from the base: step 6, image 2 of 3 Wind-up carriage clock Service clean, Detaching the movement from the base: step 6, image 3 of 3
    • The movement is now no longer protected by the case. The escapement platform at the top is delicate. Take care not to knock it. If you like, you can skip ahead to the next step to remove it and put it somewhere safe before continuing with this step.
    • Examining the two horizontal pillars at the base of the clock which connect the front and back plates, you will see that each has a threaded hole for a screw to clamp the movement to the base.
    • Noting where those screws are, peel back the felt on the base further to reveal the screw holes.
    • Remove the two screws and put the base aside.
  7. Wind-up carriage clock Service clean, Removing the hands: step 7, image 1 of 2 Wind-up carriage clock Service clean, Removing the hands: step 7, image 2 of 2
    • The hour and minute hands are simply a push-fit on the concentric spindles that turn them.
    • Grip the minute hand either side of the spindle, between your thumbnail and a fingernail, and pull it off.
    • In the same way, remove the hour hand.
    • When you come to replacing the hands you can simply push them back on, the hour hand first. Make sure they are both accurately aligned on the 12 so that the hour hand will point directly to an hour every time the minute hand passes 12.
  8. Wind-up carriage clock Service clean, Removing the clock face: step 8, image 1 of 2 Wind-up carriage clock Service clean, Removing the clock face: step 8, image 2 of 2
    • The clock face has 4 pins attached to the back which fit in holes in the front plate. At the rear of the front plate, those pins have transverse holes into which tiny tapered pins fit in order to secure them.
    • Remove each of the tapered pins in turn by gripping the thicker end with a small pair of pliers and pulling. These pins are easily lost - put them somewhere safe.
    • If the pins don't come out easily, make sure you're holding the clock mechanism firmly so as not to jerk it violently if a pin comes out suddenly.
    • You can now lift off the clock face and put it aside.
    • Do not attempt to remove the tapered pins by pushing on the thin ends - they will most likely only bend.
  9. Wind-up carriage clock Service clean, Removing the platform escapement: step 9, image 1 of 2 Wind-up carriage clock Service clean, Removing the platform escapement: step 9, image 2 of 2
    • The platform escapement is a horizontal platform straddling the front and back plates and attached by four screws. It was clearly visible with its oscillating balance wheel through the top glass before you removed the case.
    • Notice how an arbour and pinion descend below the platform. The pinion engages with the contrate wheel, the final wheel in the gear train.
    • With a small screwdriver, loosen the screws until you can lift the platform off.
    • The platform escapement is delicate. Put it aside somewhere save when you remove it and don't attempt to disassemble it - that's a job for a watchmaker!
    • If you can leave the screws in their screw holes, so much the better. It will make it easier to replace the platform escapement as these screws are quite small.
  10. Wind-up carriage clock Service clean, Unlocking the back plate: step 10, image 1 of 1
    • You are approaching the point of no return! But never fear, you WILL be able to get all those arbors with their pivots, wheels and pinions back together again.
    • There are 4 pillars connecting the front and back plates The back plate is locked by tapered pins inserted into a hole in the end of each pillar where it protrudes through the plate, in the same way that the clock face was attached to the front plate, only with slightly larger pins.
    • Remove each of the tapered pins in turn by gripping the thicker end with a pair of pliers and pulling. They may be stiff. Hold the clock frame firmly to avoid it being violently jerked if a pin comes out suddenly.
  11. Wind-up carriage clock Service clean, Removing the back plate: step 11, image 1 of 2 Wind-up carriage clock Service clean, Removing the back plate: step 11, image 2 of 2
    • Gently and progressively lift the back plate off the pillars joining it to the front plate. As you do so the pivots of the gear train will be released from the pivot holes in the rear panel.
    • As you lift off the rear plate some of the gears of the gear train may lift out of their pivot holes in the front panel. If so, gently remove them and reinsert them temporarily in their pivot holes in the front plate.
    • You will now have a forest of arbors. Take a photo of the gear train with the rear plate removed, or maybe several from different angles. This will be greatly helpful on reassembly.
  12. Wind-up carriage clock Service clean, Removing the gear train: step 12, image 1 of 3 Wind-up carriage clock Service clean, Removing the gear train: step 12, image 2 of 3 Wind-up carriage clock Service clean, Removing the gear train: step 12, image 3 of 3
    • Some of the wheels will be blocked from being removed by others. Starting with one which is not blocked at all, lift them all off in turn and put them aside in order of removal. Take another photo after removing each one.
    • Finally, remove the drum containing the main spring.
    • Two more wheels remain, secured to the front plate by a screw. These form the reduction gear between the minute and hour hands. Remove the retaining screw and lift the wheels off.
    • On the back of the back plate you will see a small piece of brass with two screws in it. One of these, covering the contrate wheel pivot hole, is an end float adjustment for the contrate wheel. Do not adjust this. The other attaches it to the back plate. Remove this screw and put the brass piece aside.
    • Another brass piece secured with a screw covers the ratchet wheel. REmove this too.
    • The clock is now fully disassembled. Take another photo of all the bits so that tomorrow you can brag to all your friends about how you got it all back together again!
  13. Wind-up carriage clock Service clean, Cleaning the gear train: step 13, image 1 of 1
    • The Introduction introduced you to the two types of clock cleaning fluid. Whichever you choose, a margarine tub makes a good cleaning bath. If you chose the ammoniated solution you'll be glad of the lid to keep the smell in when you're not using it.
    • Take each item from the gear chain in turn, soak it for a little while and then clean the pivots with a nylon brush. Use a magnifying glass to check that they are completely clean with no residual black deposits on the pivots.
    • Rinse with clean water (preferably deionised water if you live in a hard water area). Dry carefully with a paper towel, finishing with a hair dryer or hot air gun on a low setting.
    • The process is similar for the front and back plates except that you will need a thin hardwood stick such as a sharpened cocktail stick, a toothpick or a sliver of spit bamboo, or better still, pegwood. (Pegwood sticks are available cheaply online.)
    • Examine the pivot holes carefully with a magnifying glass to ensure they are completely clean. It may take several attempts but is well worth the effort. Do not proceed with reassembly until you are certain they are 100% dry.
  14. Wind-up carriage clock Service clean, Reassembling the gear chain: step 15, image 1 of 3 Wind-up carriage clock Service clean, Reassembling the gear chain: step 15, image 2 of 3 Wind-up carriage clock Service clean, Reassembling the gear chain: step 15, image 3 of 3
    • This is the bit you thought would be nearly impossible, but it's not actually very hard.
    • With the front plate flat on the table, first replace the two minute-to-hour wheels,
    • Referring to the photos you took earlier, insert all the arbors into their pivot holes in the reverse order to that in which you removed them.
    • To make sure everything is properly in place, check that every wheel except the contrate wheel engages with a pinion. (The astute reader will have noticed that in the photos, I had the contrate wheel and its predecessor the wrong way up. But it gave me more practice in aligning pivots with pivot holes!)
    • The square main spring winder and minute hand adjuster are taller than any of the pivots. Lower the back plate onto these and onto the four posts joining the front and back plates.
    • At this stage, none of the pivots will be lined up with its pivot holes, but with the back plate at a very slight angle, it will be resting on one of the pivots. Gently manoeuvre this into its pivot hole.
    • Repeat for each pivot in turn. Once all the pivots are in their pivot holes (double check that they indeed are) you should be able to press the back plate down onto the four pillars as far as it will go.
    • Holding the back plate firmly in place try gently spinning one of the wheels and check that all the others turn completely freely. You can now reinsert the locking pins.
  15. Wind-up carriage clock Service clean, Lubrication: step 16, image 1 of 1
    • As we've said before, use nothing but specialist clock oil.
    • Each of the pivot holes in the front of the front plate and the back of the back plate is surrounded by a little well. This retains the oil by surface tension. Add a tiny drop to each one.
    • Do not attempt to oil the escapement platform. In a good quality clock this will have jewelled bearings. They are not likely to need cleaning or lubricating, and the method of doing so is different and much harder.
  16. Wind-up carriage clock Service clean, Checking the contrate wheel end float: step 17, image 1 of 2 Wind-up carriage clock Service clean, Checking the contrate wheel end float: step 17, image 2 of 2
    • For all the other arbors it doesn't matter if there's a little play allowing them to move back and forth by a tiny amount between the front and back plates as the wheels will still engage with the pinions. But not for the contrate wheel as this would alter the depth of engagement with the pinion on the escapement platform.
    • Replace the small brass piece covering the contrate wheel pivot hole. Adjust the screw over the pivot hole by the tiniest amount, first of all anticlockwise, until there is the least perceptible play. Check that the contrate wheel still turns completely freely.
    • You can wind the main spring by a minimal amount to check that the contrate wheel turns freely. Unwind it once you are satisfied.
    • Also, replace the ratchet (make sure it's the right way up) and its retaining brass piece, engaging it with the ratchet spring.
  17. Wind-up carriage clock Service clean, Replacing the escapement platform: step 18, image 1 of 2 Wind-up carriage clock Service clean, Replacing the escapement platform: step 18, image 2 of 2
    • You can now replace the escapement platform. Do not completely tighten the screws.
    • Visually check that the escapement pinion is fully engaged with the contrate wheel, but not pressing on it, otherwise it will create friction and prevent the clock from running as long as it should. Examine with a magnifying glass.
    • Tighten the screws and check the escapement platform hasn't moved in doing so. Wind the main spring just a little and make sure the clock runs.
    • It's critical to ensure both that there is minimal endfloat in the contrate wheel, and that it engages fully but doesn't press on the escapement pinion.
  18. Wind-up carriage clock Service clean, Replacing the clock face and hands: step 19, image 1 of 3 Wind-up carriage clock Service clean, Replacing the clock face and hands: step 19, image 2 of 3 Wind-up carriage clock Service clean, Replacing the clock face and hands: step 19, image 3 of 3
    • You can now replace the clock face, lining up its 4 pins with the holes in the front panel. Insert the tapered pins to secure it.
    • Press the hour hand, then the minute hand onto their spindles, lining them both up accurately at 12 o'clock.
  19. Wind-up carriage clock Service clean, Replacing the case: step 20, image 1 of 3 Wind-up carriage clock Service clean, Replacing the case: step 20, image 2 of 3 Wind-up carriage clock Service clean, Replacing the case: step 20, image 3 of 3
    • Offer up the movement to the clock base and secure it with the two screws.
    • If any of the glasses came out of the case, replace them, not forgetting the plastic strips in the grooves, which should be at the top ends of their grooves.
    • Offer up the case to the base and insert the 4 screws. Do not completely tighten them.
    • With just enough clearance remaining between the base and the vertical pillars for the rear door hinge pins, insert the top pin in the top of the door into the top of the case.
    • Line up the bottom of the door with the hinge pin hole in the base and tighten the nearest screw to secure the door hinge.
    • Tighten the remaining base screws.
    • Wind the clock and make sure it's working. Once you've shown that it runs for a full week, you can glue back or replace the felt on the base.
2 other people completed this guide.
Philip Le Riche
31,973 Reputation
47 Guides authored
Restart Project Member of Restart Project
Local Repair Groups
26 Members
379 Guides authored
1 Guide Comment
Philip, that’s excellent! Thank you also for the kind acknowledgement.
One minor point worth stressing is that, when assembling the back plate and trying to get the pivots into their holes, it often (but not always) helps to start with the larger pivots in the bottom of the plate, and work gently upwards. Be very careful not to break a pivot - especially with the fine pivots found in carriage clocks, it’s all too easy to snap off a pivot, and subsequent repair requires professional and expensive attention!
Congratulations again on an excellent iFixit guide.
Phil
Phil Harris - Reply Share
Past 24 Hours: 4
Past 7 Days: 16
Past 30 Days: 99
All Time: 3,233
