Introduction
This guide will walk you through the steps on replacing the crankshafts on a Windsor Willow.
To separate the Master Link, hold the left side of the link in your left hand and the link to the right in your right hand. Push the two links together to enable the release. Pull the links apart, one hand moving towards yourself and the other away from you. This will separate the links of the chain.
The crank arms can be located between the front and rear tire, directly below the seat.
To remove the crank arm, place a proper fitting Allen wrench into the slot at the center of the crank arm as shown. Turn the wrench counterclockwise to loosen the bolt that keeps the crank arm on the bike until it spins easily. Hold the other crank arm in place to ensure that the bolt loosens instead of spinning the crank arm.
