Wintec Filemate Clear 7" Battery Replacement
  1. Wintec Filemate Clear 7" Battery Replacement, Remove the Backplate: step 1, image 1 of 1
    • Locate the four corners of the backplate.
  2. Wintec Filemate Clear 7" Battery Replacement: step 2, image 1 of 2 Wintec Filemate Clear 7" Battery Replacement: step 2, image 2 of 2
    • Pry off the backplate by inserting a spudger or plastic opening tool into each corner and popping them open.
  3. Wintec Filemate Clear 7" Battery Replacement, Remove the Battery: step 3, image 1 of 1
    • Un-stick the battery from the motherboard assembly with the plastic opening tool.
  4. Wintec Filemate Clear 7" Battery Replacement: step 4, image 1 of 1
    Tool used on this step:
    Buy
    • Desolder the battery wires from the motherboard.
    • The tweezers pictured point to the two solder joints.
  5. Wintec Filemate Clear 7" Battery Replacement: step 5, image 1 of 1
    • Fully remove the battery from the device.
To reassemble your device, glue the new battery to where the old one was and solder the new power connectors where the old ones were. Then follow the instructions in reverse order.
3 other people completed this guide.
Nicholas Ferraro
431 Reputation
6 Guides authored
USF Tampa, Team 19-6, Blackwell Spring 2014 Member of USF Tampa, Team 19-6, Blackwell Spring 2014
USFT-BLACKWELL-S14S19G6
3 Members
11 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 30
All Time: 1,010
