Wintec Filemate Clear 7" Motherboard Replacement
  1. Wintec Filemate Clear 7" Motherboard Replacement, Remove the Backplate: step 1, image 1 of 1
    • Locate the four corners of the backplate.
  2. Wintec Filemate Clear 7" Motherboard Replacement: step 2, image 1 of 2 Wintec Filemate Clear 7" Motherboard Replacement: step 2, image 2 of 2
    • Pry off the backplate by inserting a spudger or plastic opening tool into each corner and popping them open.
  3. Wintec Filemate Clear 7" Motherboard Replacement, Remove the Battery: step 3, image 1 of 1
    • Un-stick the battery from the motherboard assembly with the plastic opening tool.
  4. Wintec Filemate Clear 7" Motherboard Replacement: step 4, image 1 of 1
    Tool used on this step:
    Buy
    • Desolder the battery wires from the motherboard.
    • The tweezers pictured point to the two solder joints.
  5. Wintec Filemate Clear 7" Motherboard Replacement: step 5, image 1 of 1
    • Fully remove the battery from the device.
  6. Wintec Filemate Clear 7" Motherboard Replacement, Motherboard: step 6, image 1 of 1
    • Locate each of the motherboard's 4 mm screws.
  7. Wintec Filemate Clear 7" Motherboard Replacement, Unscrewing Everything: step 7, image 1 of 3 Wintec Filemate Clear 7" Motherboard Replacement, Unscrewing Everything: step 7, image 2 of 3 Wintec Filemate Clear 7" Motherboard Replacement, Unscrewing Everything: step 7, image 3 of 3
    • Remove each of the four 4 mm screws from the motherboard pictured to the left.
    • Use a Phillips #00 precision screwdriver.
  8. Wintec Filemate Clear 7" Motherboard Replacement, Detach the Motherboard: step 8, image 1 of 2 Wintec Filemate Clear 7" Motherboard Replacement, Detach the Motherboard: step 8, image 2 of 2
    • Use the spudger to pry the instrument array from its plastic housing.
  9. Wintec Filemate Clear 7" Motherboard Replacement: step 9, image 1 of 1
    • Slowly slide the spudger underneath the adhesive tape to un-sitck it.
    • Be careful not to harm the array of wires leading to this tape.
  10. Wintec Filemate Clear 7" Motherboard Replacement: step 10, image 1 of 1
    Buy
    • De-tatch the motherboard output wires from the screen using the tweezers.
Nicholas Ferraro
431 Reputation
6 Guides authored
USF Tampa, Team 19-6, Blackwell Spring 2014 Member of USF Tampa, Team 19-6, Blackwell Spring 2014
USFT-BLACKWELL-S14S19G6
3 Members
11 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 105
