Wintec Filemate Clear 7" SD Card Replacement
  1. Wintec Filemate Clear 7" SD Card Replacement, Pop out the Hard Drive: step 1, image 1 of 1
    • Locate the hole on the bottom left hand side of the backplate.
  2. Wintec Filemate Clear 7" SD Card Replacement: step 2, image 1 of 1
    • Press into the hole until you feel or hear a clicking feeling or sound.
  3. Wintec Filemate Clear 7" SD Card Replacement: step 3, image 1 of 1
    Tool used on this step:
    Buy
    • The SD card should be protruding from the slot. If it does not pop out on its own, you may need to use tweezers to remove the drive.
    • Remove it from the slot.
Nicholas Ferraro
431 Reputation
6 Guides authored
USF Tampa, Team 19-6, Blackwell Spring 2014 Member of USF Tampa, Team 19-6, Blackwell Spring 2014
USFT-BLACKWELL-S14S19G6
3 Members
11 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 4
All Time: 235
